Old 02-01-2011, 12:12 PM   #1 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
Jeep Liberty Nose Drop
what would be the easiest way to lower the front end of a Liberty other than a lowering kit with shorter springs?
Old 02-01-2011, 12:13 PM   #2 (permalink)
Put a bunch of heavy stuff on the front.
Old 02-01-2011, 12:14 PM   #3 (permalink)
without a significant increase in weight
Old 02-01-2011, 12:17 PM   #4 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
Without actually lowering the front suspension, the only other way to "lower" the front end is to install an air dam.
In Reason we Trust
Old 02-01-2011, 12:23 PM   #5 (permalink)
that's what i figured, maybe i can get an extra set of front springs and cut a turn off of them to shorten them, rather than coughing up about $300 for a new set
Old 02-01-2011, 12:57 PM   #6 (permalink)
comptiger5000's Avatar
RaceJeep - '98 Jeep Grand Cherokee (ZJ) 5.9 Limited
90 day: 13.62 mpg (US)
Cutting the coils will make it ride poorly, in most cases. I'd try an air dam first, as lowering the front end will steepen the windshield angle, and could potentially cause more turbulence at the back edge of the roof (unless you have a kammback).
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 02-01-2011, 01:04 PM   #7 (permalink)
Depends on how much you cut. Sure, taking away from available ride travel will compromise ride quality. The question is how far do you want to go? What's the difference between cutting a spring and getting a shorter one? Answer: none.
One way to lower without affecting ride quality is to use dropped spindles. I suspect they aren't available for that Jeep.
Old 02-01-2011, 01:05 PM   #8 (permalink)
AFAIK, no drop spindles for it. The issue with cutting coils is on a progressive rate coil (most modern ones are), you're cutting away the softer part of the coil, leaving a stiffer coil overall, compared to a proper lowering spring.
Old 02-01-2011, 01:07 PM   #9 (permalink)
actually about $250, as far as physically they're pretty much the same
Old 02-01-2011, 01:49 PM   #10 (permalink)
"Proper" lowering springs are stiffer too.
