Old 04-01-2008, 09:25 AM   #1 (permalink)
awillard69's Avatar
Dakota - '00 Dodge Dakota Club Cab, Sport
90 day: 18.57 mpg (US)
Jeep - '01 Jeep Wrangler TJ Sport
90 day: 18.46 mpg (US)
Unhappy Scangauge II Question (suddenly seeing inflated MPG numbers)
I've been using my SGII on my Jeep Wrangler and am getting pretty good at economizing what I've got.
However, yesterday, I stopped at a store, five minutes, in and out. When I started up and pulled away, the SG was reporting MPG well over 20 while putting down a side street. When I got up to speed on the main road it was up over 30. It even showed me getting better MPG under acceleration! What happened?
I reset back to the defaults, reset the engine size, fuel tank. It's still showing the same overstated MPG readings. Did some setting get 'static zapped' or something? Is there another value that should be reset?
Any ideas?
Old 04-01-2008, 09:30 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
I'm not sure what happened, but that's pretty odd. If no one here has any ideas I would try contacting the SG people for advise.
PS: Welcome to ecomodder!
Old 04-01-2008, 09:41 AM   #3 (permalink)
90 day: 51.82 mpg (US)
I'm stumped - can't think of any reason you'd suddenly see inflated numbers.
If you're convinced it's screwy, I'd second Ben's advice and fire an e-mail to the company. (My experience is they've been pretty good at replying.)
Old 04-01-2008, 09:57 AM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
You might try the scangauge on your dakota, if it works there then you might want to try disconnecting your jeep battery for 10 minutes and retry it on the jeep. If it doesn't work there then it is probably the scangauge.
Old 04-01-2008, 10:54 AM   #5 (permalink)
awillard69's Avatar
I've fired off an email to the folks at Scangauge. I'll wait and see what they have to say and let you know.
Old 04-02-2008, 09:08 AM   #6 (permalink)
awillard69's Avatar
I haven't heard from Scangauge, so I did a tank fill and reset. It seems to be working fine now.
Old 04-02-2008, 04:32 PM   #7 (permalink)
Ecomodding Amateur
krousdb's Avatar
Cold Fusion - '04 Toyota Prius
90 day: 67.34 mpg (US)
I have seen the same thing happen to me 4 or 5 times. The instantaneous MPG goes to 9999 even while accelerating. That is why i dont trust the Sg as much as the Prius MFD.
Old 04-17-2008, 12:04 AM   #8 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Jeep Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Dodge Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Ford Escort LX
Welcome to the site! electronics are electronics. they're only as good as they work at the time. well at the time it wasn't good. now its quite fine!
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
NOOB: My Scangauge is way off suddenly. hondaworkshop Instrumentation 3 02-16-2008 11:12 AM
What to do when the ScanGauge shows your SUV gets horrible MPG? Ditch the ScanGauge! MetroMPG Hypermiling / EcoDriver's Ed 10 02-14-2008 05:26 PM
Highest MPG on your ScanGauge Who The Lounge 7 01-13-2008 10:00 AM
