Old 08-09-2011, 06:18 PM   #11 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
I'm due for a fill up in a couple days, and tonight I saw that I don't have to wait another tankful to get a better gas consumption reading. I had reset mileage readings and all, but I still have the "Fuel Level" displaying. I ain't no mathemutishen, but I can still make a guess as to how much gas the Ultra Gague thinks I've burned and compare it with the pump.
I did my mileage again this morning and I'm happy with how accurate it is now. As always, I'll be monitoring them all for accuracy, but I'm happy with mileage now and I expect to be happy with gas sooner rather than later.
Transmission type Efficiency
Old 08-10-2011, 11:05 AM   #12 (permalink)
Rat Racer
Wow, third post in a row! It looks like the calibration worked. This morning I was toggling from the car's A trip (tank) to the B trip to check that against the UG's mileage since calibrating it. Unfortunately my habit of paying more attention to my driving than to things inside the car bit me- I zeroed out my tank mileage. I did not pass Go, but went directly to the gas station. Adding one mile to what I remembered seeing brought my pump math to 30.18 mpg, Which was believable based on the 30.6 that my car showed last night- starting up this morning and driving cold to the gas station would have dropped the display to 30.3, satisfyingly close to the pump and my best distance guess.
Using the fuel remaining number worked well, too. The UG felt that I had burned 9.25 gallons since the last fill up, while I pupmped 9.608. It felt that I had burned 5.080 gallons since I had last zeroed out all the numbers on the UG, so I just took the difference in the tank/pump numbers and multiplied the 5.08 by that. The car display doesn't do average mpg until after one mile and it takes a while to get realistic but after a few miles the two displays were agreeably close, given the car display's only moving in 0.3 increments and the UG's average climbing quite rapidly during glides. Now I'll bump the numbers on my next few tanks and then periodically after that.
Old 08-12-2011, 06:00 PM   #13 (permalink)
Red Light Avoider
pletby's Avatar
My Civic - '00 Honda Civic DX
90 day: 46 mpg (US)
Good save Fat Charlie.
The downside of instantaneous feedback is when your car is all messed up you can see what crappy mileage you're getting. Dangit.
I calibrated my mileage and that really helped. Pretty much lines right up with reality now.
Old 08-12-2011, 06:10 PM   #14 (permalink)
Polymorphic Modder
SoobieOut's Avatar
2006 DaCivic Hybrid - '06 Honda Civic Hybrid
90 day: 45.16 mpg (US)
Alternative to A/C
Here's an option to avoid using the a/c. But the added drag may be a wash.
I have seen these at Old car shows. Only usefull in dry climates.
Congrats on your recent UG purchase!!!
Old 08-12-2011, 07:00 PM   #15 (permalink)
...beats walking...
...great minds think alike (ha,ha): http://ecomodder.com/forum/251838-post35.html
Old 08-12-2011, 11:57 PM   #16 (permalink)
Rat Racer
Check it over time. The manual wants you to roll against mile markers and says the more (and the straighter) the merrier. It mentions 3 miles. Riiiight. If I'm calculating the mileage with my odometer, I'm going to calibrate the UG to the odometer. The current calibration used a little over half a tank. A little over a half a tank later, the UG is reporting 0.5 miles and 1.5 mpg more than the car. I'll refine it over the next few tanks and then I'll be really happy with it.
Old 08-13-2011, 12:16 AM   #17 (permalink)
Red Light Avoider
pletby's Avatar
90 day: 46 mpg (US)
That makes sense. Never thought of that. I think I'll do the same. That way the two methods of finding mileage should line up if the gauge is properly calibrated.
Old 08-13-2011, 04:01 AM   #18 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
No, no. Calibrate your UG distance and odometer against a GPS. I've done it over 40, 60, 80, and 100 mile distances with three different sizes of tires on my xB. The OEM tires were off 3.3%, set A were off 9.9%, and set C were off 9%. When I'd driven 10 miles per the odometer on the OEM tires, I'd actually traveled 10.33 miles per the GPS. When I'd driven 10 miles per the odometer on the A set of tires, I'd actually traveled 10.99 miles per the GPS. The UG will show you whatever you tell it to show you, based on the distance calibration you set in your vehicle setup option.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
The Following User Says Thank You to SentraSE-R For This Useful Post:
California98Civic (08-13-2011)
Old 08-13-2011, 04:42 AM   #19 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Check wether the odometer is correct then, using GPS or many mile-markers along the road (like 20 , 30 or so instead of 3) on a longer trip.
Old 08-13-2011, 04:55 AM   #20 (permalink)
euromodder's Avatar
That's bad for your mileage - see the 100+ Hypermiling Tips.
Longest trips first, errands, tanking etc. on the way back with warm engine so the engine doesn't really cool down again and thus needs no cold restart
