Old 07-25-2009, 06:38 PM   #1 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
just tried out my new vac-gauge
at idle it reads 19-20 depending on alt load. At highway speeds it reads 12 inches in fourth gear and 17 inches in third gear. I would like to get some opinion of which gear i should cruise in because third will probably be easier for the engine, but fourth has lower revs. i just don't know if the lower revs are making up for the lack of vacuum. and i also realize that at lower revs the engine does not pull a high vacuum because it is not using that much air.
i know i will probably end up testing to find out anyway but i am wondering if anyone has been over this dilemma before.
oh and is 4 inches going uphill in fourth better than 7-8 in third?
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 07-26-2009, 10:54 AM   #2 (permalink)
The Odyssey Van - '11 Honda Odyssey EX-L
90 day: 29.1 mpg (US)
silver racecar - '13 hyundai accent GS
90 day: 38.8 mpg (US)
When I had my toyota tacoma I used a scan gauge that would read out real time air flow through the MAF meter to get an idea on my fuel being used. Take your air flow in lb/min and divide by 14.7 which will give you the lb/min of fuel being injected. I used 14.7 as this is the air/fuel ratio my o2 sensor tried to keep the mixture. I did this at 60mph so it was 1 mile per minute to make calculation easy. At 0 vac in o/d it was using roughly 5lb/min air so it was injecting .34lb/min or mile fuel. Gas is around 6lb/gallon from what I remember so I divided 6 by .34 and came up with 17.65 which will be my mpg at 60mph and 0 vac. You can do this at any speed, gear, rpm, vac, boost, conditions, ect as long as you can hold the vac/boost steady long enough to get a reading. Hope this helps.
Old 07-26-2009, 02:09 PM   #3 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
IsaacCarlson -
Cool beans. It's a 2 for 1 because the gauge will also help you "gauge" the health of the engine :
CarloSW2
American Solar Energy Society
Econometer/Vacuum Gauge Installation Guide Johnny Mullet Instrumentation 80 02-18-2015 12:58 PM
Mullet's Metro Project Johnny Mullet EcoModding Central 302 02-06-2011 07:04 PM
10-minute Accord vacuum gauge "install" Clev DIY / How-to 7 09-10-2010 03:53 AM
SGII Horsepower gauge & related gauges RobertSmalls Instrumentation 3 03-03-2009 09:20 AM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
