thanks john,
I finished welding the frame, now onto all the parts that go on it.
I know I should try working on the seat but I don't want to get bogged down this early on something hard.
Next day I plan to weld a brake bridge to the front fork since I'm using a 20" wheel. Then clean up the old head tube bearings and install it.
Then clean up the crank bearings and install bottom bracket and crank arms. I've got my eye on a 3 ring "biopace" crank a friend has on an old specialized mountain bike, but I just want to get it road worthy first then upgrade components if it's worth the effort. Maybe put the rear wheel on and a kick stand so it looks like it could roll
