Old 12-18-2008, 09:28 PM   #21 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Jeep Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Dodge Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Ford Escort LX
I have one question. After I unplug the heater and start my engine, I seem to find that when I accelerate away from my driveway that I get an instant sloshing/ water trickling sound at the dashboard (heater core). When this happens, I get instant feedback from my temp. gauge that I have hot coolant, but if I just let it sit there it doesn't get warmed up for a long while.
I've come to the conclusion that by the way I've got the block heater installed, that the coolant to the heater core moves the coolant during acceleration that is heated opens up the thermostat, letting a whole lot of coolant into the engine and getting feedback from the temp gauge.
I'm also thinking that the heat from the block heater only partially opens the thermostat, so that the coolant flows to the engine core, but cools off after a while.
I'm wondering if I should get that stubborn bolt off of the engine bay and take coolant from the engine, sending it to the heater core, and then back into the engine instead.
Although these are just theories. I've also got a mechanical fan that runs all the time, so at Idle that could not be enough to move the coolant and the mechanical fan could prevent warm up as quickly.
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 12-19-2008, 02:29 AM   #22 (permalink)
Custom User Title
Daily Driver - '02 Pontiac Grand Prix SE
90 day: 18.45 mpg (US)
Not actually adding a lot here, but the sloshing sound isn't just water rushing through the heater core, it's air as well. Water moving is quite quiet, its the air mix that produces the noises (most of it, not all). I would consider trying to get any air out of your core and lines if you can, as that'll cause issues with the pump and/or overheating (worst case scenario). My car has been doing that for a while now, just haven't gotten off my tush to fix it, so it's not bad, but not good either.
Old 12-22-2008, 01:26 PM   #23 (permalink)
ya, But I'm not sure how to go about it. I figured the air would rise and go into the reservoir tank when the Jeep got heated all the way up, but it hasn't done that.
Old 12-22-2008, 01:48 PM   #24 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
wait till your car is cool - a couple hours!!!
remove your rad cap
Idle it till it warms up and coolant starts to overflow out the rad cap (be enviro-friendly and catch that coolant).
Idle it for about 10 more minutes to allow all the air out - as you see it bubble over, pour more coolant in. Be on top of it or it will suck back air.
2003 Toyota Matrix Block Heater Daox EcoModding Central 25 11-03-2012 08:59 AM
Geo Metro Block Heater How-to bbjsw10 DIY / How-to 75 12-31-2009 12:34 AM
Oil Heater Blanket? cfg83 EcoModding Central 10 06-30-2009 12:30 AM
Coolant heater *failed* bhazard DIY / How-to 5 12-08-2008 12:32 PM
850 watt tank style coolant heater - installed in the Blackfly MetroMPG EcoModding Central 4 11-28-2007 02:10 PM
