Old 02-03-2015, 02:39 PM   #31 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
pgm-f1 causes drain
If you're using this mod, I suggest switching your Ultragauge on and off 20 times (with the engine off) with 3 second pauses, and checking the drain in your battery. The pgm-f1 in my car used .05v each time it was switched back on, thus 20 times drained 1 full volt, causing the alternator to run more when using the kill switch, and lowered mpg.
I moved the kill switch to an injector wire under the hood, and the issue went away.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 12:59 PM
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 40 06-18-2012 04:13 AM
Chrysler Expected To Kill Models, Bring Italian Vehicles Ashore Jammer The Lounge 17 06-26-2010 08:29 PM
Honda Civic 5th gen and 6th gen jennyfurwhen Off-Topic Tech 15 10-01-2009 01:44 AM
FS: Carbon Fiber Hatch for 5th Gen Civic trikkonceptz For Sale 8 06-04-2008 05:40 AM
