Old 01-18-2010, 04:32 PM   #1 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
Arrow ScanGauge II speaker mount for 2001 Toyota Echo
Ive been thinking about a SG mount for a long time now. So I fabbed one up. If you worked straight through from start to finish it will probably take you an hour or so.
I could have just drilled 3 holes in the speaker cover but I dont have a spare cover.
Its also reversible this way. I do plan to cover the surrounding hole with coroplast or something. This probably cost me $5 to make.
What I used:
Thin cardstock (for template)
Thin sheet metal
Metal snips
Metal file (to smooth edges)
Drill
Screwdriver
2 Screws
3M Velcro
I had it behind the steering wheel but its not a great place since the surface is curved.
(It'll come off eventually in time)
So I popped the speaker cover off.
My echo didnt come with tweeters so its an empty space with 2 places for screws.
I made a template out of cardstock, traced it to thin sheet metal,
then cut a plate using metal snips. I then smoothed the edges and
and screwed it down to the existing holes.
3M heavy duty "velcro" works really well and I was able to run the cord down.
(If you look through the windshield, it literally drops straight down to the OBD port)
I like how close it is to the windshield. I keep my eyes on the road
and even have a small amount of room to put up the sunshade.
Name:	Echo ScanGauge00 (Medium).JPG
ID:	5400   Click image for larger version
Name:	Echo ScanGauge01 (Medium).JPG
ID:	5401   Click image for larger version
Name:	Echo ScanGauge02 (Medium).JPG
ID:	5402   Click image for larger version
Name:	Echo ScanGauge03 (Medium).JPG
ID:	5403   Click image for larger version
Name:	Echo ScanGauge04 (Medium).JPG
Name:	Echo ScanGauge05 (Medium).JPG
ID:	5405   Click image for larger version
Name:	Echo ScanGauge06 (Medium).JPG
ID:	5406   Click image for larger version
Name:	Echo ScanGauge07 (Medium).JPG
Past Present Future?
Old 01-18-2010, 05:19 PM   #2 (permalink)
...beats walking...
...sneaky cool!
Old 01-26-2010, 03:42 AM   #3 (permalink)
Grasshopper
im still thinking of ways to make the surround
any suggestions?
Old 01-26-2010, 07:49 AM   #4 (permalink)
Fiberglass is the only thing I can think of.
Old 01-26-2010, 07:51 PM   #5 (permalink)
...beats walking...
...how about that "home-improvement" foam in a can?
...make a mold (wax paper?), spray in the foam; let it harden, sand down, and cover with suitably colored cloth, tolex, or faux-naugahyde.
...for a tight fit, wrap the SGII (without cable) in wax paper and position in as you want within the mold.
Old 02-02-2010, 07:00 PM   #6 (permalink)
recession proof rebel
k.civic.f4i's Avatar
stay away from the foam in a can!!!! it's evil. fiberglass is the way to go. fairly easy, just time consuming.
how to.....
http://ecomodder.com/forum/showthrea...cks-11998.html
http://ecomodder.com/forum/showthrea...how-12301.html
true wealth comes from good health and wise ways
Old 02-02-2010, 07:21 PM   #7 (permalink)
any suggestions?
small sheet of...
aluminum diamond plate
Carbon fiber sheet (not fabric, 6"x6" chunk should do)
fiberglass (fairly work intensive, for such a small piece)
abs plastic sheet
choroplast (if your really have to )
thin wood
thin wood upholstered
to name a few
Old 02-06-2010, 05:29 AM   #8 (permalink)
why dont you just cut a hole through the thing that was originally there enough for the bracket to fit? would look really oem. or pick one up from a junkyard and cut that up.
how to.....
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 02:36 PM
Aerodynamic Belly Pan on Toyota Echo jime57 Aerodynamics 23 12-05-2010 06:18 PM
ScanGauge II with X-Gauge: ecomodder price $149.95 smartzuuk Instrumentation 0 09-01-2009 02:07 AM
What is wrong with my scangauge II? 2000mustang fan Instrumentation 5 07-22-2008 10:45 PM
What is X Gauge (on the ScanGauge II)? NeilBlanchard Instrumentation 5 07-22-2008 08:07 PM
