Old 01-28-2009, 09:29 PM   #1 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Ford Taurus GL (Sedan)
90 day: 19.39 mpg (US)
Blue Wagon - '00 Ford Taurus Wagon SE Comfort
90 day: 19.61 mpg (US)
Best tape for attaching simple wheel skirts?
I might be going on a fairly long road trip this weekend. I would like to make some simple wheelskirts. Just a half-circle of coroplast, taped over the wheel well.
The question is what is the best type of tape to use? IMHO, Painters tape is too week, and I've used colored duct tape before but it leaves a residue on my car...
I haven't used regular silver duct tape on my car before, and I do have a roll of clear duct tape (which I am thinking might leave less residue?)...
What would you guys suggest? I don't have the time to build brackets or anything.
Old 01-28-2009, 10:11 PM   #2 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
3m double sided trim adhesive. It comes off with goof off.
Old 01-28-2009, 10:31 PM   #3 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Is that the black gooey stuff that holds ventvisors on?
Old 01-28-2009, 10:43 PM   #4 (permalink)
Yep.
Old 01-28-2009, 10:44 PM   #5 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Goof off won't damage the paint will it?
Old 01-28-2009, 10:52 PM   #6 (permalink)
Read the can - I don't believe it works on urethane based paint (so that would be a no).
I'm actually pretty sure it only works on the adhesives. If you don't trust it, use Orange clean and buff the spot when you're done.
Old 01-29-2009, 12:10 AM   #7 (permalink)
TacoModder
mobilerik's Avatar
rik's prerunner - '03 Toyota Tacoma Prerunner Double Cab TRD 4A
90 day: 29.68 mpg (US)
I haven't seen exactly what Christ is talking about, but I highly recommend 3M Double-Sided Duck Tape. Holds really well but still peels off easily and cleanly. It's thick and gummy, and will even restick really well up to a point. I've had my cab Kamm stuck on for a month now with that stuff. But as with other adhesives, cold damp weather will make it uncooperative, so pick your moments.
And Goof Off gets a thumbup, too. No problems on the car paint at all. Try Goof Off 2 in a spray.
Also for a 1-sided tape, I've gotten stronger and cleaner results with Gorilla Tape than Duck.
Old 01-29-2009, 12:14 AM   #8 (permalink)
same stuff, only you're getting the home depot version... I usually end up w/ the body shop/OEM version.
Old 01-29-2009, 12:19 AM   #9 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Yeah, I already have 4 rolls of spare tape for my ventvisors, so I'll just use that tomorrow morning it's off tithe car wash for me and hopefully Ill get them installed before work
Thanks
Old 01-29-2009, 12:26 AM   #10 (permalink)
A good hand waxing and buffing before installing the tape will improve adhesion, and (for some reason ) it will also make it less likely to damage paint in the event of melting due to direct sunlight or heat, or overexposure to the elements.
FYI.
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
Designing/building front wheel skirts v.1.0 (Geo Metro) MetroMPG Aerodynamics 124 12-26-2012 06:15 PM
DIY Rubber Front Wheel Skirts newtonsfirstlaw DIY / How-to 32 05-19-2011 07:45 AM
how to make skirts for plastic wheel arches? modmonster Aerodynamics 6 01-22-2009 11:06 PM
Wheel skirts for the aerodynamically minded Daox Aerodynamics 14 01-27-2008 11:23 PM
