Old 06-05-2009, 11:59 AM   #1 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Biologically "friendly" parts washer?
Anybody use anything like the bioremediation unit?
BioCircle Website
Old 06-05-2009, 12:04 PM   #2 (permalink)
Interesting. I've never seen something like that before.
I personally use Simple Green Pro HD (avaliable at home depot) in my parts cleaner. It is a water based cleaner and works pretty well.
Old 06-05-2009, 12:54 PM   #3 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
The place I worked at back in 1997 rented one like that for a month. It was almost worthless. Maybe they are better now, however if you use it a lot, it starts to stink real bad. I would leave it on all night soaking parts and they wouldn't come clean. I couldn't even get the oilly residue off of my parts. I just quit using it and went back to the solvent tank or the caustic soap.
Old 06-07-2009, 01:13 AM   #4 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
this brings me back to the early 1990s as well. I was a grub in the pit stall at a quick lube, cleaned tranny pans if need be. It ended up being simply kerosene type cleaner, the rest was as crazy as mobil 1 at the time (mobil1 was not an instant winner for you oil fans..Shhhh) The biofriendly excuses walked away with dollars and no real result.
anyway, years later, I help clean an independent drivers rig, and there is still no excuses. gonna put ingredients together that create something nasty, like oil and antifreeze and even freon...there needs to be an equal enemy.
I hope they do come out with something, for now, there is the "barely legal" caustic stuff that folks can use at home... and once even a true external clean happens, the benfit of such a cleaner stops crazy things mixing in the first place, as cleaning is a preventative. It is only bad in wrong places, like everything else
Old 06-08-2009, 02:15 PM   #5 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
How effective is steam cleaning for removing built-up oil and gunk? I want to steam-clean my engine compartment so I can start tracking down leaks. Anybody found a reasonably cheap (sub $150) steamer that works?
Old 06-08-2009, 03:30 PM   #6 (permalink)
EcoModding Punk
LeanBurninating's Avatar
Honduh Power - '98 Honda Civic HX
90 day: 44.37 mpg (US)
I would ask around at local shops in your area. Depending on your living situation it may be best to have it done somewhere besides your home. The places that will steam clean an engine compartment and underside are becoming few and far between because its not easy dealing with all that gunk with new regulations and stuff. But if you do find one, they'll probably help you out for less than $100.
Good luck.
Old 06-08-2009, 03:46 PM   #7 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Steam-cleaning is extremely effective, just like pressure washing is... if you get a steam genny, you'll have almost effortless cleaning. If you can't get access to one, simple green and a hose-attached soap dispenser (or fertilizer dispenser) will work too. Don't let it sit on rubber/neoprene hoses too long, they'll soften.
Old 06-08-2009, 10:21 PM   #8 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
I've used one; works very well. Excellent if you have an A/C shop.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Places to get OEM Honda Parts TomO Off-Topic Tech 10 06-02-2009 01:56 PM
Research - Parts - Weights electricman General Efficiency Discussion 2 02-22-2009 09:18 PM
Suggestion for getting parts in Canada? (not @ ratshack) MetroMPG OpenGauge / MPGuino FE computer 15 10-23-2008 10:07 AM
Advanced auto parts Lazarus The Lounge 4 01-03-2008 09:06 PM
