Old 01-20-2009, 02:38 PM   #11 (permalink)
Tracy - '00 vauxhall corsa
i like the thermocouple idea. ill defiantly do that. i'll drill into the cat somewhere with a drill the same diameter as the thermocouple. then super glue it in place. is that the best fixation method? maybe i can trap a thermocouple in between a flange connection somewhere?
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
Old 01-20-2009, 02:42 PM   #12 (permalink)
i take it that measuring the manifold temperature is not good enough?
Old 01-20-2009, 02:54 PM   #13 (permalink)
The EGT probe should be as close to the head as possible. Drilling into the manifold is a much better idea. Take a look at how commercial EGT gauges are mounted.
Old 01-20-2009, 03:05 PM   #14 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Superglue most certainly will not hold anything to your exhaust FYI. You'll need a welder, silly.
Old 01-21-2009, 08:06 AM   #15 (permalink)
welding is belond my skill level
Old 01-21-2009, 08:29 AM   #16 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
No need to weld. Drill, tap and screw a fitting.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 01-21-2009, 11:12 AM   #17 (permalink)
EcoModding Newbie
Parachute - '03 Chevrolet Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Plymouth Neon Highline baby!
90 day: 31.39 mpg (US)
Slocus Wagon - '06 Ford Focus SE
Even just wrapping some wire around the thermocouple and the manifold should be good enough, you are just looking for consistant contact so you can compared the stock settings manifold thermocouple voltage and your new voltage once you lean the engine out. You don't really need to know what the actual temps are.
Anyways, don't wreck your car for a few mpg...
If your exhaust looks anything like this, you are probably in for big repairs!
Old 01-21-2009, 02:07 PM   #18 (permalink)
cant i just wedge it in between a flange joint somewhere and back it up inside to reach the manifold?
lean burn rules~! coolwHip Introductions 42 10-01-2011 06:42 AM
My Kingdom for a NOx Sensor cfg83 EcoModding Central 19 08-25-2010 07:55 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 01:39 PM
lambda sensor for lean burn engine fabrio. General Efficiency Discussion 1 03-31-2008 05:15 PM
MAF sensor life Daox Off-Topic Tech 9 03-25-2008 03:29 PM
