Old 12-12-2009, 03:49 PM   #11 (permalink)
Try it without the defroster on, floor vents only. In my ZX2, whenever the a/c compressor runs (like in defrost mode), the engine cooling fan came on. I disconnected the wire to the compressor and it still did it. I pulled the a/c fuse and now it only comes on when it gets hot enough.
The Following User Says Thank You to moorecomp For This Useful Post:
j12piprius (05-04-2014)
Old 05-06-2014, 06:24 PM   #12 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
how to turn off the condenser fan
I'd like to turn the condenser fan off, as I don't ever use the a/c. The #17 7.5a fuse on the civic runs both the a/c, and power mirror #1 which I'd rather not turn off as it doesn't have a manual control. Is it okay to remove the condensor fan relay and the a/c compressor clutch relay?
Old 05-06-2014, 06:49 PM   #13 (permalink)
...beats walking...
Simply unplug the relay and tape the connector closed (to keep water out).
The Following User Says Thank You to gone-ot For This Useful Post:
j12piprius (05-06-2014)
Old 05-06-2014, 07:00 PM   #14 (permalink)
Liberty Lover
j12piprius's Avatar
Thanks. I've removed both relays. By connector, do you mean to tape the sockets?
Old 05-06-2014, 08:07 PM   #15 (permalink)
...beats walking...
Yes, sorry, I should have been more specific: "connector sockets"
Old 05-07-2014, 08:27 PM   #16 (permalink)
Liberty Lover
j12piprius's Avatar
fuse #56
Aha, I was checking the wrong fuse. The correct one is #56 in the relay box by the battery. I've pulled the fuse and put the relays back in.
Old 05-07-2014, 08:31 PM   #17 (permalink)
Liberty Lover
j12piprius's Avatar
connecting led light to the fan
Originally Posted by Chalupa102 View Post
Finally got the led to work . When i was coming up the hill just now to get to my road it came on at 204° and when off at 202°. Thanks everyone for ur help with this.
How did you connect the leads to the fan? The wires connect to my fan with a clip, and there's no place to connect to them, unless I splice to the wires. The wire would probably break in the clip.
Old 05-08-2014, 01:25 AM   #18 (permalink)
90 day: 29.78 mpg (US)
I've wanted to do this mod for some time, but...
I can tell when my cooling fan turns on because the temp on my UltraGauge will go from 215 F down to 195 F in a hurry, and then slowly start creeping back up again. I also have an alarm set that warns me when I go above 209 F.
At least 1 fan runs all of the time when I have the AC on. This also keeps the coolant temps well below the 215 F threshold when both fans kick on high.
My LED tail light conversion BrianAbington EcoModding Central 52 12-06-2011 06:42 PM
LED Headlight captainslug DIY / How-to 82 11-15-2011 01:32 AM
PCB design for led bargraph battery monitor mora DIY / How-to 30 10-20-2011 11:02 AM
LED lighting goes mainstream! It's at Wal-Mart! bennelson Saving@Home 81 08-07-2010 11:18 AM
Article: Hella LED Headlamp Study TomO General Efficiency Discussion 14 10-21-2008 02:39 PM
