05-02-2008, 12:29 PM
EV OR DIESEL
Time for new Well Pump
Well the the Well (not so much the pump) went dry.
Time for a new/ deeper one I suppose
Any suggestions?
I've got a well service who will be here soon to take a look/ fix it.
I was just considering Eco-Modding anything while there is an opportunity (not that I can think of anything at the moment)
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
05-02-2008, 05:21 PM
Depends on the Day
Solar with a battery charge, and AC for when the batt dies?
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
05-02-2008, 05:53 PM
Lurking footless halls
Originally Posted by Frank Lee
Lotsa iron in the water? Maybe the sandpoint is plugged up. Sometimes they can be cleared with acid and/or blasting caps.
I had mine hydro-frac'd and it's been fine for 10+ yrs
Any sufficiently advanced technology is indistinguishable from magic. - Clarke's Third Law
05-02-2008, 10:53 PM
EV OR DIESEL
TONS of Iorn in my water.
Should I try and pour some acid down hole?
Should I ask the well guy about blasting caps?
Well guy said to pull it out and call him back. I don't think he wanted to fuss with it as it is in the bathroom of my Guest House. I have to pull a cabinet, the celling , and the Roof to pull the pipe out the ground.
Thank you guys very much for the info
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
05-02-2008, 11:23 PM
Start collecting rain water?
Around here it's not leagle to put a well in a building, so it sounds like you get to pull the guess house apart!
Any idea how deep the well is? any idea if the well really went dry, or if the pump stopped working? if it's simply the pump, then replace it, 220v is better then 110v for pumps because the motor is more efficient, less line loss in the wires and I think they are over all just cheaper, I think you will also save a little bit if you have a larger pressure tank as your pump is not turning on and off as much where it has to start that motor from a dead stop, drawing alot of power for that first few seconds.
You can still buy new hand pumps...
05-02-2008, 11:32 PM
EV OR DIESEL
I do collect rain water for use at my camp, works great. if I didn't have a swimming pool I could get away with it most of the time at home. May do that in the interim . . .
Pump still works, in fact it is pumping pool water up to pressure right now supplying the house with water.
Bigger pressure tank is a very good idea!
Pump is already 220
No Idea on how deep the well is . . .
Pump was outdoor, then a shed was built, then the house became mine, then I built a room, then it became a guest house with real ceiling, cabinets etc etc.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
05-05-2008, 08:18 PM
EV OR DIESEL
Totally NON eco advice needed, but fast would be GREAT
I puled the pump/ pipe out (cut it in to 8 foot lengths) out to find that the foot valve was MISSING, the male adapter had sheered off.
Well is 60 feet
Anyways I re-assembled it, (lots of couplers) but now I have a leak between the Casing and the Flange, I was not aware that there was any pressure there . . . . .
Should I seal it up (doesn't look like anything was sealing it before)?
Did I assemble it in-correctly?
googling now . . .
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
05-06-2008, 05:58 PM
EV OR DIESEL
Learned a lot in the past day
1) center pipe is (1") is 60 feet
2) Casing is approx. 200 feet deep
3) water level is about 55~60 feet deep at this moment
4) Pump requires a "jet" to operate <- Never heard/ seen one before
5) New PVC pipe is very flexible, it can be maneuvered through a cabinet, a bathroom, a bedroom and through the door :-)
6) Submersible pumps are FAR FAR more efficient. a 1/2 hp submersible will do 13 GPM at 100 feet, while my 1hp (actual running draw in operation was about 900~950 watts) Jet pump can do 2 gpm at 60 feet
7) Smallest submersible pump sold is 3.5" OD (my casing is 2" ID)
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
