Gasoline Fumes -- That's apparently quite effective. What was the previous air dam like? The hood and fender gaps are tightened up in the later picture. Did that and the tire deflectors get you to 70mpg?
Originally Posted by California98Civic
Here is one of my favs: lower side skirts made from painted and then plasti-dipped rain gutter
It was just some black paint i had on hand to paint what was originally white rain gutter. I painted over it with plasti-dip when I was doing a lot of the trim in plasti-dip and wanted the exact same black hue and texture all around.
The previous air dam:
My guess is that most of the air was still getting under the car.
Those gaps are just because the bumper wasn't bolted on yet.
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
pris prius - '12 Toyota plug in prius 90 day: 71.09 mpg (US)
Hey gasolinefumes, what function is the solar charger for? Battery? How well does it work for you?
Originally Posted by Gasoline Fumes
It also should increase my range with the alternator disabled. I've been doing that on short trips lately.
I have one, but thought driving at the same time would cause it to short out.
Do you plug it into the power outlet in the dash, and leave it plugged in all the time?
This was Version 2 of my grille block. Duct tape over cardboard for testing purposes. Survived 2 months of rain, then ended up getting soaked. V 3 will be coroplast and will happen soon!
"Delicate and orchestrated operation is often required as an Eco-Driver." - RH77
"Some things aren't true, but I choose to believe them. Because it is my right as an American." -Ratking11
The Following User Says Thank You to Flakbadger For This Useful Post:
