Old 04-10-2010, 04:33 PM   #1 (permalink)
Lighter valve springs for better mpg?
I was thinking about changing them to lighter ones.This is on a 95 Camry le 4cyl.Has anyone done this already? I read about this somewhere,maybe here?
Old 04-10-2010, 05:18 PM   #2 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
I would not for your engine.
there are strange cases in the past where one part did everything..
a good example is the old subaru I am driving. It is simply a 9to1 engine, with a carburator...
the same engine had a turbo edition. all springs very hard, all versions. Even the oil pump is absolutely gigantic without the turbo.
this is very rare to think about. I would leave oe springs alone.
I am still not going to change my cold tappers..23 years doesn't happen to everything..
Old 04-11-2010, 12:40 AM   #3 (permalink)
If you will never rev the engine up to higher RPMs, you might be able to get away with that without grenading the engine. You might reduce the friction in the engine by a few percent, depending on what's in there now.
IMHO, not nearly worth it. I'd look into other mods, like increasing tire pressure and possibly getting taller gearing.
-soD
Old 04-11-2010, 10:31 AM   #4 (permalink)
Location: Ampang Jaya, Ampang, Selangor, Malaysia, Earth.
IMHO, weaker spring will cause those valves 'floating' at higher rpm...
Old 04-11-2010, 01:39 PM   #5 (permalink)
How about making some sense?
Old 04-11-2010, 03:38 PM   #6 (permalink)
Hyperlurker
daring4's Avatar
D-max - '04 Chevy Silverado Ls
Notch - '65 Volkswagen 1500 S
MTCHBX - '05 Scion XB
90 day: 40.41 mpg (US)
I almost spit beer all over my laptop!
Old 04-11-2010, 03:59 PM   #7 (permalink)
Smurfback - '01 Chevrolet Blazer LS
I'd like to hear more on this. With the LS engine series GM moved to "beehive" springs. They were able to lower seat pressure and maintain performance. Your Camry may already have them, it would be worth checking. As far as I know the aftermarket is pretty small on them in general.
Google beehive valvesprings for more info.
Old 04-11-2010, 05:42 PM   #8 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
lmao
To OP:
There was a HUGE thread about this a few months ago, and the general consensus around here was...it wouldn't be worth it.
Old 04-11-2010, 08:39 PM   #9 (permalink)
Hyperlurker
daring4's Avatar
The time and expense to change springs would not be worth it IMHO. Tire pressure increase would have more positive affect than less valve spring tension. You will not be happy if you float the valves and bend 3 of em!
Injector kill switch would be way better and easier to do, not to mention cheaper.
Old 04-13-2010, 09:30 AM   #10 (permalink)
90 day: 51.82 mpg (US)
Much more discsussion in this thread:
http://ecomodder.com/forum/showthrea...ctic-6960.html
Search is your friend!
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Lighter valve springs - an OEM efficiency tactic MetroMPG EcoModding Central 40 11-24-2015 03:57 PM
free OBD2 software with MPG calc whitewiz Instrumentation 11 12-10-2014 10:53 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
SGII first observations! gone-ot Success Stories 10 04-02-2010 01:26 AM
