Old 06-07-2010, 08:04 PM   #1 (permalink)
I have to start over?
Big inefficient truck - '94 Dodge Ram 2500
90 day: 12.1 mpg (US)
Honda Civic - '84 Honda Civic DX Hatchback
basic questions about prebuilt MPGuino
I plan to buy a prebuilt MPGuino, but have found myself procrastinating on my purchase because I realize that I have no idea where I would begin to handle fixing the code. Would I even need to play with the code, or is it ready to go as soon as I hook it in and set the VSS and injector paramaters?
I guess this would be a good opportunity for a succinct abstract over the prebuilt. If I have missed it, sorry. Could you point me in the right direction?
What I want to think (but have doubts about) is that I just tap into the injector lead, get a VSS signal, calibrate the params (from within the MPGuino), and enjoy the feedback.
Also, how long is the usual handling time?
Old 06-08-2010, 11:19 AM   #2 (permalink)
HX1 - '98 Honda Civic HX
90 day: 48.08 mpg (US)
PriusG2 - '09 Toyota Prius II
90 day: 47.91 mpg (US)
PriusG2-MFD - '09 Toyota Prius II
90 day: 50.3 mpg (US)
Volt1 - '14 Chevy Volt
You are correct. I ordered mine, got it quickly and then installed by connecting power, ground, vss and injector. Set parameters based on other people with the same car and started refining my driving techniques. I had reset/freezing problems with the original place I got the power connection, so I connected power through a fuse to the battery and have had no more problems.
Prius MFD fuel Log
Prius Gallons at fill up Log
Old 06-08-2010, 12:09 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
re: programming, it is a complicated A lot of folks get their feet wet with an arduino or clone, but the latest source code is completely divorced from arduino, and the prebuilt hardware is not arduino. The prebuilt has a faster crystal (20mhz vs 16), only supports the atmega328 currently, no bootloader, no onboard serial or usb circuitry, pins dedicated to LCD/buttons/sensors.
For the prebuilt, and atmegas in general, avrfreaks.net is probably a better source of info.
FYI, I'm using avrgcc to compile and avrdude to load the chip and fuses, with an isp programmer, and a homemade clip-on programming adapter.
Old 06-08-2010, 03:09 PM   #4 (permalink)
Thanks guys. My main concern is that I have no apparatus to get into the code, not to mention that I haven't had my feet wet with code, really. I had a comp sci class, and we went mostly over Java, but that was too long ago to do me any good
Old 06-08-2010, 10:40 PM   #5 (permalink)
With the prebuilt, will I have to worry about corrupting the data with the power being unplugged?
Old 06-08-2010, 11:09 PM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
If unplugged, the vehicle settings will stay, but the tank trip will reset.
Old 06-09-2010, 09:23 AM   #7 (permalink)
I meant if the power was disconnected and reconnected within 20 seconds. Is that just the arduino?
Old 06-09-2010, 09:42 AM   #8 (permalink)
dcb
needs more cowbell
dcb's Avatar
oh, well I haven't seen a prebuilt erase itself in a long time, we've been making tweaks to keep that from happening (i.e. no bootloader, no self programming at all, bigger caps, rearranging the power circuits to keep the brain alive longer, etc. But of course that doesn't mean it won't ever happen to the prebuilt. I have done things like connect the mpguino power through a big file and drag the conductors along it (insanely erratic power), and it still had the right programming. But solid power is still probably good thing.
My arduino based version forgot its programming several times when the power was flakey, but this isn't conclusive, but reason enough for me to not retain arduino-ness.
Old 06-09-2010, 01:00 PM   #9 (permalink)
Thanks. I'm looking forward to its arrival
DCB, I PM'd you
Old 06-09-2010, 04:24 PM   #10 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
I also have a couple questions about the prebuild. Does it come with any casing, or is it a bare chipset?
Also, would the VSS be the wire coming into the speedometer, and would any injector wire work?
In Reason we Trust
mpguino, prebuilt
'97 Chevy Cavalier Install and Questions maverick21016 OpenGauge / MPGuino FE computer 3 05-21-2010 01:33 PM
Mpguino prebuilt, know what you are buying dcb OpenGauge / MPGuino FE computer 0 10-24-2009 04:27 PM
MPGuino newbie questions mhopeng OpenGauge / MPGuino FE computer 2 06-28-2009 04:01 PM
A Few MPGuino Questions Axaday OpenGauge / MPGuino FE computer 12 07-23-2008 12:28 PM
Questions about mpguino mhmitszach OpenGauge / MPGuino FE computer 37 07-01-2008 07:38 AM
