Old 07-09-2011, 06:26 PM   #1 (permalink)
Little help with INJ signal, on a motorcycle
Hi there,
Im considering the MPGuino, but first i need to know if i can get the right INJ singal
The bike is a Honda CBF125, with PGM-FI fuel injected by Keyhin.
The thing is: im almost sure that is a wire pink/green the INJ signal, but i dont know how i should measure it. Voltimeter? + to wire, and - to ground (engine earth)?
What values should i expect when accelerating?
thank you a lot
