Old 11-12-2008, 08:13 PM   #1 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Locking an automatic in a single gear?
I was browsing through Craigslist and found a Geo Metro for sale, cheap, with a title and a pretty good body.
The engine is bad, its a four cylinder with an automatic transmission.
Made me think, too bad it's an auto, otherwise it would be a perfect EV conversion.
But then, why couldn't it be? And why use it as an automatically-shifting transmission?
Is there some way to lock an automatic transmission in one particular gear? I know gear selectors usually have a Low,2nd, drive sort of a selection.
A couple summers ago, I got to drive a Solectria Force Geo Metro conversion. The body was that of an automatic transmission. I don't recall exactly what it had for a transmission in it.
What is required for an automatic transmission to run? What if it doesn't have to shift automatically? Could this be a decent EV conversion?
If not, what would be required to swap it over from automatic to a manual transmission? Do manuals and automatics have the same flywheel in them?
Just throwing some ideas out there.
-Ben
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 11-12-2008, 09:51 PM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
What do you mean the body was that of an automatic? You mean it was a sedan?
As far as I know, the Solectrias had a single speed custom transaxle. Don't need gears with a 12 or 14k RPM AC motor.
Assuming it's old school, you just have to turn the input shaft to build up fluid pressure. More modern computerized transmissions need all kinds of sensor & ECU input to work well. (Not an issue with the Metro).
Auto EV's have been done. There's an automatic Metro sedan conversion under way on YouTube:
Personally I don't like the idea of a conventional automatic in an EV. Even if it only costs you a 5% efficiency loss, that's too much. :P
Old 11-12-2008, 10:21 PM   #3 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
Unplug all the connectors on the trans and I think it turns into a manual valvebody where you have to manually select a gear to drive in. I am not sure about that since the most I have done with an automatic metro is just yank the trans and toss it but I am pretty sure I read that on teamswift somewhere.
You can drive it directly without a torque converter so that gets rid of a big loss right there. The only other issue I can think of is you need the pump to be pumping all the time while rolling to keep it working so it would need a second motor to drive the pump. Not really sure how all of that could be rigged up but I am sure it is possible.
One nice thing is the way an automatic shifts gears means you can probably change gears without stopping like you would have to most of the time with a clutchless manual setup.
Old 11-12-2008, 11:58 PM   #4 (permalink)
Maybe it can be done but I think you are barking up the wrong tree.
Old 11-13-2008, 02:36 PM   #5 (permalink)
Not really a problem, with practice. I'm up & downshifting a lot (without stopping) in the clutchless manual ForkenSwift. No bad noises either! Rev match on the downshift, use the right pressure on the shifter, and you're good to go.
Old 11-13-2008, 04:46 PM   #6 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
I would think that an auto trans (old style) would be hella easier than any other option.
Just a side note - why don't you EV freaks ever talk about CSV? WAAAAY better on paper, and you're not putting down heavy torque (which is the excuse for no mass production in typical vehicles)
Old 11-13-2008, 07:50 PM   #7 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
HEY! NO ACRONYMS! EYA! (Explain your abbreviations!)
My YouTube Videos
Old 11-14-2008, 12:25 AM   #8 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Typically there are 2 solenoids in a 4 speed Auto. Opening + closing the 2 solenoids select the 4 gears. Applying 12 volts to the proper solenoids will give you 1 gear. However you will have to turn the pump to make fluid pressure to hold the clutches . . . . . Wasteful . . .
Here's a link to the Gear Vs Solenoid position for the AE340
MK3 TSRM On-Line
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 11-14-2008, 08:20 AM   #9 (permalink)
Haha... i'm so sorry... total brain fart on my part... i meant CVT... not CSV... ie... constantly variable transmission, as opposed to manual or auto.
Old 11-14-2008, 09:34 AM   #10 (permalink)
EcoModding Newbie
Parachute - '03 Chevrolet Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Plymouth Neon Highline baby!
90 day: 31.39 mpg (US)
Slocus Wagon - '06 Ford Focus SE
Matt,
Electric motors make more torque that gas ones of similar hp and I believe most electric motors have the same efficiency almost anywhere in their rpm band. So a CVT isn't really needed for them and they are few % less efficient than a manual trans. Probably the best EV solution is not to have any transmission at all with a motor than can produce enough torque to start and enough rpm to do 60mph.
Ian
Story of a custom 5th gear for a '98 Ford Escort ZX2: +6% MPG MetroMPG EcoModding Central 14 03-05-2020 06:20 AM
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Saturn S-Series 5th Gear Swap cfg83 EcoModding Central 61 05-02-2012 09:31 PM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Met an unhappy Aveo owner today MetroMPG General Efficiency Discussion 24 10-10-2010 07:03 AM
