03-25-2015, 01:12 PM
#11 (permalink)
Rat Racer
That G1 may not be exactly what you're looking for:
But at least it's in good shape.
Overal a great running car
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
03-25-2015, 01:16 PM
#12 (permalink)
Modder status:Noob Saibot
Originally Posted by Daox
1st gen Civic hybrids also had manual (and lean burn). 1st gen Insights 00-07 were the only ones with manual trans. 2nd gens are all CVT.
Thanks a million! I think this might be exactly what I was looking for. Any chance you could tell me what years the G1 Civic hybrid ran?
That being said, I have to agree with Neil. Driving a Prius or EV is not a lazy affair if you're trying to get good FE. However, you can still set the cruise and get great mileage too.
I must say that I agree with you here entirely. My short experience with driving the '05 Prius led me to believe that I could definitely be in tune with such a vehicle, as I would definitely be trying to max out my FE, but I don't think I could ever feel the same "in-tuneness," for lack of a better word, that I feel when shifting gears.
03-25-2015, 01:21 PM
#13 (permalink)
1st gen civic hybrid is 03-05, not all of the 5 speeds had lean burn. You could also look into the manual transmission Honda CR-Z HYBRID
The Following 2 Users Say Thank You to Insight for life For This Useful Post:
03-25-2015, 01:26 PM
#14 (permalink)
I totally get that. I specifically traded my last car for the 5 spd Metro to get a manual trans.
03-25-2015, 01:27 PM
#15 (permalink)
Interesting. How can you tell the difference? 5 wire O2 sensor?
03-25-2015, 01:48 PM
#16 (permalink)
Originally Posted by RedDevil
Direct response just like a manual, but without having to shift, ever.
But I WANT to shift, always :-)
For the OP, if you want something newer than the Gen1 Insight, the CR-Z hybrid also comes with MT.
03-25-2015, 02:09 PM
#17 (permalink)
This guy knows what's up! xD
The age of the car isn't an issue as long as it's mechanically sound, so as it stands, these are my options: - G1 Honda Insight ('00-'07)
- G1 Honda Civic Hybrid ('03-'05) *may or may not have lean burn*
- Honda CR-Z Hybrid ('??-Present)
EDIT: I think I'm starting to fall in love with Honda, even though they seem to be phasing out my love for changing gears.
PS: I plan to edit the OP later, and include a master list, so that this thread can be more accessible to those with similar idiosyncrasies. :D
03-25-2015, 02:48 PM
#18 (permalink)
So, is it only G1 Insight, or G2 as well? As of right now, this looks to be the only option.
EDIT: A used Honda Insight looks to be my only option.
If I did not have my Sentra so close to fully sorted out I would be all over that Insight in Cocoa Florida, assuming it had no serious defects other than the clear coat paint issue.
regards
mech
03-25-2015, 03:16 PM
#19 (permalink)
My Insight has flappy paddles so I can shift it if I want to.
It then has 7 preset fake gears that lock the CVT into a fixed ratio.
I have used it to good effect descending a hill in 2013 to increase engine braking, which also increases low speed power regeneration.
Since then, IIRC I accidentally pulled one once last year.
Other than that, I dont use it
My cruise control buttons show signs of wear.
03-25-2015, 04:41 PM
#20 (permalink)
There are quite a few threads on the G1 Insight floating around. I have one in this section that you might be interested in.
I love my car.
