Old 10-04-2015, 07:05 PM   #1 (permalink)
Carbon Abuser
iamnotahippee's Avatar
Olaf - '03 Honda Civic Hybrid
Sven - '06 Volvo Xc90 2.5t
Work Truck - '04 Chevy Silverado 3500
Looking at grille block options for the HCH
I am ready to make a grille block for the HCH. I am trying to decide how i want to go about it. Here is a pic for reference...
Now my preference is to go clear across the front, fog light to foglight with a 1 piece block. I feel that would be the "cleanest" way to go. I am probably going to use white sheetmetal for the block. I have some sheetmetal at work that is big enough to make individual blocks for the front. Are we looking at a big enough difference between a 1 piece and individual blocks? On the HCH the H on the grille is actually an air duct that allows airflow. The lower slit in the "grille" is also airflow. The area under the chrome strip is just merely for decoration and drag, it dead ends to nothing, so I am going to find a solution for sealing that up. I am hoping by leaving all the upper grille area open I can get sufficient airflow for cooling. Also, with fall temps dropping, hopefully that will work in my favor also.
So thoughts on the best plan for my air blocks?
Rob
1986 Chevy C-10 10mpg Grandpa's Truck
2004 Chevy 3500 diesel 10mpg The work Truck
2003 Honda Civic Hybrid 5 spd ?? Mpg My Carbon Pentance
Old 10-08-2015, 08:36 PM   #2 (permalink)
Carbon Abuser
Well, I got froggy and made some small grille blocks. I am going on a trip this weekend, so we will see how things happen.
If I can get a bigger piece of sheetmetal I am going to make a one piece grille block and really try to make a nice super smooth front bumper. I have driven it the last to afternoons with cranking and no temp problem.
Well here is to aerodynamic modifications!
The Following User Says Thank You to iamnotahippee For This Useful Post:
aerohead (10-09-2015)
Old 10-09-2015, 10:22 AM   #3 (permalink)
Could you describe how did you mount them?
Old 10-09-2015, 12:17 PM   #4 (permalink)
Carbon Abuser
I just used some screws i had on hand. They were screws for mounting sheet metal to wood framing. I just screwed the metal panels to the plastic bumper cover. If you look carefully you can see the screws. 2 on the outer covers, 3 on the middles.
Old 10-09-2015, 02:42 PM   #5 (permalink)
Hybrid Pancake - '03 Honda Civic Hybrid
90 day: 56.01 mpg (US)
notahippee, do you have a way of accurately monitoring the coolant temperature? The factory temp. gauge on that car hits mid way at around 164 and stays there well past 200.
Old 10-09-2015, 02:57 PM   #6 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Block looks good.
My scientific way of dealing with coolant temp is to open the block a bit if the fans come on at stop lights. I find that you can usually get away with a full lower block off peak summer temps. They were designed for worst case scenario: Death valley mid July, fully loaded, driving up a steep hill. Still, a coolant temp gauge is much preferred.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 10-11-2015, 11:20 PM   #7 (permalink)
Carbon Abuser
Well we clocked almost 400 miles this weekend. No sign of overheating and the ac never missed a beat. I feel that we are good with air flow. Now I need to fix the IMA, because 35-40 mpg is not cutting it!
aerohead (10-12-2015)
