Old 05-31-2014, 10:20 PM   #1 (permalink)
backpacker3's Avatar
Homer - '02 Pontiac Sunfire SE
Team Pontiac
90 day: 30.05 mpg (US)
Looking for a little help with OBDuino build.
I'm reading through the OBDuino thread so I know what I'm doing when I go to build mine but I just want to make sure that I'm understanding everything correctly since this is my 1st arduino build and I don't want to mess it up. Can someone check my parts list for me please?
My car:
2002 Pontiac Sunfire SE Sedan
2.2l Ecotec
4 Speed Auto
VPW (J1850) Protocol
Parts List :
- Arduino (I'll use the SainSmart Arduino Uno)
Link --> Amazon.com: SainSmart UNO R3 ATmega328P Development Board + USB Cable Compatible With Arduino UNO R3 Mega 2560 Nano Robot: Computers & Accessories <--
- LCD I'm still deciding on the size
- OBD-II Wire
- Resistors
Will these 2 work? --> 220 ohm 1/2W 5% Carbon Film Resistor pk/5 : Resistors | RadioShack.com <--
--> NTE QW151-10 - 1/4W 510 Ohm Metal Film Flameproof Resistor | RadioShack.com <--
- Transistor (I only need 1 right?)
PNP Amplifying Transistors (15-Pack) : PNP Transistors | RadioShack.com
- Buttons to switch screens
These are normally open
3A 125V SPST Normally Open Pushbutton Momentary Switch : Pushbutton Switches | RadioShack.com
I've never tried any arduino projects before but I have programming knowledge and I'd like to give it a try I just want to make sure I really do my research first. Thanks for any help.
Picture is of the type OBD-II connector in my car.
Last edited by backpacker3; 06-05-2014 at 09:28 AM.. Reason: Updated parts list and protocol added
Old 06-02-2014, 08:46 PM   #2 (permalink)
Team Pontiac
Bump for updated parts list.
I'll check the protocol my car uses tomorrow cause it's raining now
EDIT: Protocol is now listed in OP
EDIT: I'm dropping some links here so I can find them easier
https://code.google.com/p/opengauge/wiki/OBDuino32K
Source code
https://code.google.com/p/opengauge/...no/obduino.pde
Last edited by backpacker3; 06-06-2014 at 10:40 AM.. Reason: Putting some link here for future reference
Old 06-06-2014, 10:44 AM   #3 (permalink)
Team Pontiac
Well no my biggest problem is figuring out the OBD II cable from the schematics I was looking at there are a few extra wires since my car only has 4 pins and the pictures in the OBDuino project are all not working so it says "the cable should look like this" but then the picture is missing so I'm not sure what this is. Lol
Does anyone have a picture or instructions on how to make the cable?
Old 06-06-2014, 05:36 PM   #4 (permalink)
Team Pontiac
Also do I need an ELM?
Old 06-15-2014, 10:47 PM   #5 (permalink)
Hi
Thought this device would be redundant by now ,the ËLM sorts out which protocol the vehicle has automatically ,then spits out the appropriate info to the arduino.
Resistors are ok & one transistor is right.
the cable I can't recall .
Old 06-16-2014, 08:29 AM   #6 (permalink)
Team Pontiac
Thanks I'm going a bit of a different route now you can check out my plans here http://ecomodder.com/forum/showthrea...2-a-29179.html
What do you mean by it being redundant though?
Old 06-16-2014, 06:25 PM   #7 (permalink)
When I say redundant , the blue tooth OBD elm device to the smart phone & the ultragage ,plus other devices , are probably reasons the pages for the OBDuino are no longer maintained.
I started looking at this about 3 years ago ,that is as far as I got.
Old 06-16-2014, 11:32 PM   #8 (permalink)
Team Pontiac
I see what you mean now. That's why I'm tiring to build one without the elm I don't want to have to use my phone for that cause I don't want to always have it plugged in or be draining the battery but the elm only uses Bluetooth now. That's why I'm hoping to do be able to read & clear DTCs on the OBDuino build I'm doing it gives a bit of incentive to make one. Of you're interested in it I don't mind your input on the build in the other thread I think I'm about ready to order my parts for the OBDuino 2 ( I guess that's what I'll call it ) and try it out.
