Old 10-04-2014, 01:05 PM   #11 (permalink)
Lath and plaster tooling
tooling can also be made with lath and plaster.The original Corvette tooling was done this way.
The 'plug' can be plaster as well as the female mold.Slit-molds for complex forms.
Georgia-Pacific makes a full line of industrial tooling plasters.
There's no 'stink'.No hazardous vapors.
Tooling epoxy, "plastic-faced" plaster molds can be used for limited production runs.
Even drywall compound can be used for one-off studies.After priming, painting,color-sanding,and polishing with acrylic lacquer and polyvinyl alcohol with three coats of carnauba wax,a perfect part or mold can be pulled.
Ferro-cement can also be used for tooling,even metal forming,but get help lifting as this is a 'heavy' proposition.
Beyond small batch production you'd want to graduate to Kirksite alloy tools.
Old 10-04-2014, 03:01 PM   #12 (permalink)
My parents cut foam on a homemade 'jigsaw'. It's long gone, but I still have the Lionel transformer from it. As I recall about 70% throttle was used.
Let's not forget Ed Roth. He made a male mold and then chipped it out from the inside of the new body.
aerohead (10-04-2014)
Old 10-06-2014, 05:36 AM   #13 (permalink)
But if there are more work to do, I would buy a foam plotter.
CNC Foamplotter zum Schneiden von Styropor und Styrodur
Old 10-06-2014, 02:23 PM   #14 (permalink)
It might do better for most people's needs on this forum if it was US$85.10 instead of 1.580,00 €.
I tried really hard to get what the cutter tool is without looking at the English page and failed. Then I looked at the English page and all it says is:
Z-AXIS (3)
(3)Length of the cutting wire
so I don't feel so bad.
The part of the process I'd be concerned about is that the stacked sections of foam leave as much as √2x the thickness of the section undefined. The uncertainty is less in flat areas and greatest at creased edges. Would you stack thinner sheets in areas that need definition, or embed a wire along the crown of the crease? A localized cut and fill, where you shave material, mix it in a [differently colored] matrix and refill it into the low spots would give you an average surface. ...and create less dust. A correctly averaged surface would show twice as many edges at the original stack.
