03-01-2012, 08:49 AM
Lugging
I have a question regarding lugging while P&Ging.
Most of my commute is on roads with speed limits in the 30-40 mph range.
When there is no traffic behind me, I will generally glide down to close to 30 mph, which is about my minimum 5th gear speed (V-6 ranger, 5 speed stick).
If I extend my glide a little to long or have some sort of uphill, I sometimes get into the lug zone a bit. I can stay in 5th, with very light throttle and accelerate very slowly, smoothly, or I can momentarily drop to 4th or sometimes 3rd, accelerate hard and be back into 5th fairly quickly.
Which is better?
Do I burn more fuel putting up with a few seconds of very light throttle to nurse it out of the lug zone or should I go to a lower gear where I can go to a more efficient 80% throttle.
I do not have a scan guage, unfortunately.
Does anyone have a BSFC graph for the vulcan 3.slow V-6?
03-01-2012, 10:46 AM
I'd suggest downsifting anytime you're lugging. You don't have to keep the rpms THAT low.
03-01-2012, 11:08 AM
Also: get a scangauge! It'll pay for itself. (And you can always re-sell it later.)
Note there are less expensive options than the full SG 2, such as the ScanGauge E and the UltraGauge.
03-01-2012, 12:03 PM
that's the thing. I'm at a point where I am not really lugging at low throttle inputs, but am if I step on it.
i am guessing that downshifting probably does make sense in this case, as fuel efficiency just above lugging, probably ain't anything to write home about.
i 'spose a little extra left leg exercise is good for me, anyway and doesn't really cause much extra wear.
03-01-2012, 12:25 PM
Hypermiler
What rpm are we talking about? I like to run mine fairly low, pulsing from 1300 rpm on up. What's efficient is 80% LOAD, not throttle. At very low rpm, that load level comes with the throttle just above idle.
03-01-2012, 01:48 PM
Not really sure what the revs are, as I have no tach. Interesting point about the difference between load and throttle position. I wasn't aware of it.
I 'spose I will modify my p&G technique a bit and incorporate 3rd/4th gear a bit.
03-01-2012, 01:50 PM
Pokémoderator
Pete -
Happens to me all the time. I downshift if I need to accelerate quickly. If I need to increase my speed and I can take my time then I am super-gentle on the throttle until I get out of the "lug zone".
Me too.
CarloSW2
03-01-2012, 02:12 PM
Smeghead
I think the art of driving efficiently has more to do with how you decelerate and what you do with your velocity once you have it than how you accelerate. Use a gear that allows moderate acceleration and a throttle position that is just backed off of where adding more does not increase acceleration rate. That is about as good as you can do without instrumentation.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
