Old 02-17-2009, 01:03 PM   #11 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Any instant (or even very fast) method of warming the engine block is probably going to crack, melt, or warp something.
Another method I have heard of is building a fire on the ground under the engine. But I would not try it.
I would rather take a cord to my car than a pot of boiling water anyday.
I thought someone in here mentioned a block heater that patched into a radiator hose and circulated the coolant. Though to make it effective, I would think you would need some sort of a thermostat bypass.
Winter daily driver, parked most days right now
Summer daily driver
Old 02-20-2009, 05:47 PM   #12 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 Scion xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
Ages ago, my dad had a 1985 Plymouth Horizon, and he used a trouble light and a packing blanket (he used to be a trucker-- there's a whole stack of those things in my parents' garage), and that apparently worked relatively well.
Of course, you have to remember to un-tuck your engine in the morning. My dad failed to do that once, and considers himself very lucky to not have yanked the blanked into the belts, or started the car on fire.
Old 02-20-2009, 06:19 PM   #13 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Hello -
How about an electrified dip-stick that could heat the engine oil directly? It would have to be the "right metal" to take it, but I think that would be a pretty safe way to heat the oil.
CarloSW2
American Solar Energy Society
Old 02-20-2009, 06:38 PM   #14 (permalink)
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
Kats dipstick heater - Google Search
Old 02-20-2009, 08:15 PM   #15 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
TestDrive -
Originally Posted by TestDrive View Post
Thanks for the google. Me likey. Seems like you could use it for other things, like boiling the largest cup of tea in the world.
EDIT: Hrrrm, not convenient if I have to plug it in overnight :
http://www.warehouseautoparts.com/Sp...ick_heater.htm
Connect oil heater into any 120 volt outlet and operate on an all-night basis. It is important to begin operating oil heater when car engine is still warm. Check heater clearance from hood, before closing hood. Be sure no wires or cables come in contact with heater.
CarloSW2
Old 02-20-2009, 09:03 PM   #16 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
My thinking is, a block heater puts its heat right into the engine where you need it. Alternatively, the kind that installs into a heater hose would probably be a close second.
If you live in REALLY cold country, or if you live in kinda cold country and drive lots of short trips where the car stays cold for a high percentage of the drive time, one of the above would probably be a good idea. Service shops and parts stores in those areas are familiar with those heaters.
The other solutions, while clever and they help, lose a lot of their heat to the environment. So, not worth the effort.
The electric blanket might get around the heat loss issue if you put an insulating blanket over it to trap the heat. But if you actually LIVE in cold country, I doubt that you'd make plans to fool around that way on cold mornings. I live in Connecticut, and the last thing I want to do when it's 10 degrees out and I need to get to work, is fool around with the car. Get in, turn the key, and go. Fastest way to warm up is to drive it.
You do get better mpg out of a cold car by EOC: engine off coasting. It takes longer to warm up that way, but overall mpg is higher over any given distance, measuring from a dead cold start.
Coast long and prosper.
Old 02-21-2009, 12:54 AM   #17 (permalink)
93 Metro Streamliner
AeroMetro - '93 Geo Metro
Originally Posted by modmonster View Post
pouring boiling water is instant
No, it certainly is not instant. It takes a long time for the metal to absorb the heat from the water. You would have to stand there pouring boiling water for at least 20 or 30 minutes, and it would take many gallons.
2003 Toyota Matrix Block Heater Daox EcoModding Central 25 11-03-2012 08:59 AM
Civic Block Heater Install TomO DIY / How-to 42 04-04-2012 08:24 PM
Geo Metro Block Heater How-to bbjsw10 DIY / How-to 75 12-31-2009 12:34 AM
Motorcycle + block heater = stupid idea? extragoode Motorcycles / Scooters 14 11-29-2008 09:43 PM
An Engine Block Heater in San Jose Who EcoModding Central 20 07-28-2008 05:44 PM
