Old 02-16-2009, 04:10 PM   #1 (permalink)
Tracy - '00 vauxhall corsa
macgyver block heater idea?
how about pouring boiling water on your engine in the mornings?
would that be an effective way of heating the engine quickly?
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
Old 02-16-2009, 05:03 PM   #2 (permalink)
90 day: 51.82 mpg (US)
Unfortunately, it might be an effective way to crack something!
The most MacGyverish block heater methods I've heard of are:
- tuck a couple of 100w light bulbs in there
- drain & prewarm your engine oil (I've heard of people doing this in extreme cold - ie Arctic - conditions). Probably only useful if you've got a lot of oil volume.
- shove a propane fired catalytic type burner under the front of the car (I've heard of some towing companies doing this too)
Why not just use a block heater?
Old 02-16-2009, 05:04 PM   #3 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Jeep Cherokee
90 day: 17.18 mpg (US)
ZX7R Ninja - '99 Kawasaki ZX7R Ninja
90 day: 42.45 mpg (US)
I would think depending on the temps it would have a tendency to freeze rather quickly and not really warm up the inside of the engine much. You would probably be better off figuring out a way to remove some of the coolant and bring it inside to warm it up. Just dump it back in when your ready to go.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 02-16-2009, 05:29 PM   #4 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
a year or so back the Farm Show magazine had an artical about a product that was a propane powered block heater, basically a very small propane water heater that had two hoses on it with hydrolic quick connects (high pressure with valves that close when you pull the hoses apart), I have thought that a system like this that would hook in to a heat exchanger on your hot water heater in your house and a small pump that would pump hot water in to your engine would work well and with the heat exchanger you could keep your antifreeze without risking a spill.
Old 02-16-2009, 05:47 PM   #5 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
90 day: 42.72 mpg (US)
Closest thing I can think of to warming up the engine without a block heater is just parking it in a heated garage or using an electric blanket (though this has disaster written all over it to me, without some waterproofing precautions) and I'm not even sure if the latter would really warm up the engine fast enough.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 02-16-2009, 06:00 PM   #6 (permalink)
a block heater takes too long and you need a cord running to you car. pouring boiling water is instant
Old 02-16-2009, 06:44 PM   #7 (permalink)
I think it would make a bigger mess than anything else.
Ice all over the ground.
The hot water would be heating the outside of the engine. We want the heat more on the inside.
Old 02-16-2009, 07:17 PM   #8 (permalink)
Hi,
The stories about warming up the Model T's engine include removing the spark plugs, and putting them in the wood stove until they are cherry red, and then reinstalling them...
Old 02-16-2009, 07:29 PM   #9 (permalink)
The Model T guys also did the "take the water and oil in the house and heat em up there" thing too.
Old 02-16-2009, 10:24 PM   #10 (permalink)
Heating the oil was standard procedure for starting WW1 aircraft engines in cold weather, in particular, the Jenny.
A relative had an auto repair business in a coastal resort town many years ago. Mercedes, especially, would not start in foggy weather. He took an extension cord and a blanket, left the blanket on the engine a while, came back later to start the car.
He claimed he made good money that way.
Ray Mac.
2003 Toyota Matrix Block Heater Daox EcoModding Central 25 11-03-2012 08:59 AM
Civic Block Heater Install TomO DIY / How-to 42 04-04-2012 08:24 PM
Geo Metro Block Heater How-to bbjsw10 DIY / How-to 75 12-31-2009 12:34 AM
Motorcycle + block heater = stupid idea? extragoode Motorcycles / Scooters 14 11-29-2008 09:43 PM
An Engine Block Heater in San Jose Who EcoModding Central 20 07-28-2008 05:44 PM
