The Following User Says Thank You to JulianEdgar For This Useful Post: | aerohead (09-18-2020) |
09-17-2020, 07:16 PM | #14 (permalink) |
Cyborg ECU
Black and Green - '98 Honda Civic DX Coupe Team Honda 90 day: 66.42 mpg (US) Black and Red - '00 Nashbar Custom built eBike 90 day: 3671.43 mpg (US) Thanks: 2,373
That is a clean and convincing test. Super cool.
See my car's mod & maintenance thread and my electric bicycle's thread for ongoing projects. I will rebuild Black and Green over decades as parts die, until it becomes a different car of roughly the same shape and color. My minimum fuel economy goal is 55 mpg while averaging posted speed limits. I generally top 60 mpg. See also my Honda manual transmission specs thread. |
The Following User Says Thank You to California98Civic For This Useful Post: | JulianEdgar (09-17-2020) |
09-17-2020, 09:12 PM | #15 (permalink) |
I thought I'd dig out my scope and look in more detail at the action of the smoothing circuit on the suspension height sensor.
The circuit: Cost - just a few dollars. Note the adjustment pot (1 meg) that allows the smoothing time to be set. For this test I wired into place an additional pot so that I could alter the input voltage just by turning a knob. On the scope pics the blue trace shows the input signal and the red trace, the output signal. The vertical scale is 2V per division and the horizontal scale, 5 seconds per division Scope pic 1. You can see that at the 5 second mark I abruptly decreased the input voltage. You can then see it took about 7 seconds for the output to settle at the new level ie this pot position gave about a 7 second smoothing time. You can also see how the quick fluctuations are completely damped out. Scope pic 2 In this one I have reduced the smoothing time. Note how now it takes a shorter time for the output to follow the input (about 3-4 seconds) and how the quick fluctuations are now not completely smoothed. The circuit values can give a smoothing time from 0 to about 15 seconds. In use you set the smoothing pot so that at a constant speed, flat and straight road, the values settles to consistent and readable value within a reasonable time. |
09-18-2020, 11:54 AM | #16 (permalink) |
spoiler testing
That's good work Julian. Thanks!
The only thing I'd like to mention, refers to a ' SHOWDOWN FOR SPOILERS', which was published long ago, in CAR LIFE Magazine, June, 1969. A flip-up rear spoiler was fitted to a Chevrolet Camaro Z/ 28, and tested in an un-disclosed stretch of highway near the California / Nevada state line, USA. At 115-mph, the spoiler created a pitching moment, lifting the nose with 400-pounds ( 180-kg ) force, while providing 125- pounds ( 56.5-kg ) rear downforce.
Photobucket album: http://s1271.photobucket.com/albums/jj622/aerohead2/ |
09-18-2020, 11:53 PM | #17 (permalink) | |
Thanks.
The Following 2 Users Say Thank You to JulianEdgar For This Useful Post: |
09-23-2020, 10:24 AM | #18 (permalink) | |
figures
They tested both airdams and rear spoilers, at 65, 85, and 115-mph. -------------------------------------------------------------------------------------- For the Camaro, the rear spoiler by itself generated 125-pounds rear downforce, plus 400-pounds of front lift. The most stable condition was with just an airdam. ------------------------------------------------------------------------------------- The Pontiac GTO 'JUDGE', with tail-mounted, elevated spoiler, added front lift, with zero rear downforce. -------------------------------------------------------------------------------------- The American Motors Javelin's roof-mounted spoiler produced no measurable effect at any speed. ---------------------------------------------------------------------------------- This is why I mentioned maybe doing front axle loads on your sons car. It's hard to predict what will happen on any given vehicle.
09-23-2020, 03:55 PM | #19 (permalink) | |
The Following User Says Thank You to JulianEdgar For This Useful Post: | aerohead (09-24-2020) |
09-24-2020, 02:32 PM | #20 (permalink) | |
cars of that shape
Originally the car had no front lift. With 17.8mm of spoiler height they achieved the drag minimum, while adding some rear downforce, however it also introduced front lift. With increasing spoiler height the downforce continues to climb, however with increasing drag and front lift, up to a point.
