07-03-2020, 05:59 PM
1993 Mercedes w124 diesel modifications
Did my first engine modification yesterday, removal of throttle plate(this is a diesel engine)
People I talk to say it is purely for creating vacuum to activate EGR nothing else, since this car was imported it has EGR, many same engine and yearmodel cars were built without this.
This is how it looked like before
Nice, finally gone and yuk full of soot from the EGR
End result
And what can I say after driving 160km(100miles)
WOW!!!  never thought it would make this big difference, she has a lot less engine braking so I can coast a lot longer (automatic transmission) and partial throttle response is a lot better,
in fact partial throttle response is so much better that I can leave her in D instead of manually shift to 3rd gear when city driving at the speeds 30km/h and 40km/h.
Same thing in roundabouts no need to use kickdown(or manually downshift) to get her initally moving out of the roundabout, she scoots a lot quicker with less throttle input (or rather the need for full throttle in city driving is gone now)
Another positive is that engine stays cooler, before even during the winter short idling in traffic lights made temp go quite high and it was slow to go down to normal again, now it is slow to rise and fast to go back to normal
The bigger question is, how will this affect fuel consumption  my guess is probably for the better
1993 mercedes w124 200D automatic 75hp
1989 mazda 626 2.2 automatic 116hp
07-04-2020, 12:37 AM
What about the effect of this mod to the brakes? Aren't them vacuum-assisted too? On a sidenote, in Brazil I'm aware some people adapted throttle plates to Mercedes-Benz OM-314 engines in order to improve engine-braking, even though I would rather resort to an exhaust-brake for that matter.
07-04-2020, 02:14 AM
No effect at all on brakes
like all diesel engines this also has a vacuum pump for the brakes and since it is older style mercedes, this vacuum is used for central locking mechanism and engine shutof also
Like I wrote above this engine was also made without EGR, only difference is intake, exhhaust, a few linkages and pipes between exhaust and intake
So this throttle plate only function is to allow intake get clogged with soot from EGR
Later I will get the non EGR exhaust manifold and intake to increase efficiency even more and make room for water injection (this EGR intake is also very big and makes engine bay crowded  )
07-04-2020, 04:02 AM
Eco-ventor
Isn't it going to fail inspection if you disable EGR?
07-04-2020, 05:32 AM
Here no, but depending on where you live it might, the egr is still there and everything around it
the thing with EGR on diesel is that if you want it to work it needs cleaning from soot almost once a year, google if you wish to learn more
07-05-2020, 01:22 PM
Cyborg ECU
Does water injection work in a diesel?
07-05-2020, 05:40 PM
Of course  it is great on supercharged engines but even NA benifit from it, reduces soot and NOx, cleans combustion chamber
The downside is that water freezes during winter
07-05-2020, 09:45 PM
Adding some alcohol prevents the water from freezing, plus it becomes easier to vaporize.
Since it had a throttle plate, it got me wondering if Mercedes-Benz would've eliminated the vacuum pump.
07-06-2020, 04:39 AM
#9 (permalink)
Yeah i know, methanol is the preferred alcohol, it even adds some energy (power) problem here is it is very very expensive, only cheapish alcohol is E85 and then you gotta remove the gasoline after blending it with water.... only other solution is washer fluid wich also is ethanol here and quite expensive
My though was that they maybe also used the vacuum for the automatic gearbox but they did not, it seems to be only EGR wich is nice
07-06-2020, 06:02 PM
#10 (permalink)
Is homebrewing vodka totally out of question?
So, does its torque converter not feature a lock?
