Old 11-01-2010, 07:40 PM   #1 (permalink)
Saturn TDI nose job...
Just a few quick pics of my Saturn TDI nose job; I fitted a couple pieces of lexan around the lower front fascia to block off the grille opening (which is really huge) and, at the suggestion of my son, modified the headlight brackets to move the headlights forward about an inch, bringing them flush with the leading edge of the hood.
The car warms up faster and maintains a higher operating temperature than it usually does for this time of year, and coasts a lot further, too! I was part-way through a tank of diesel when I did this last week, but I got my all-time best of 57.45 mpg! I usually get around 54-55 mpg, so I was really happy about that, and hope to see an even higher figure when I fill up again.
The car has a small chin spoiler to duct air up into the intercooler (kind of hard to see in the picture), but I have a couple of ideas in the works to make a bigger/better one to help reduce some of the air passing under the car, and making a sort of hinged trap door to allow more cooling in warmer weather, but easily drawn shut in cooler weather...something that I can regulate from the drivers seat. I'd also like to mount the rearview mirrors inside the car as I've seen several people do on this site - just too many ideas and not enough time to do them in!
The Following User Says Thank You to Craig For This Useful Post:
Cd (11-05-2010)
Old 11-01-2010, 08:04 PM   #2 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Craig -
Neat mods. I can't think of anyone that has moved the headlight in the past. To see an all-time high *after* summer is a great sign.
CarloSW2
American Solar Energy Society
Old 11-04-2010, 07:04 PM   #3 (permalink)
Saturn TDI Conversion - TDIClub Forums
This is the build thread for the car; I'm having a lot of fun with this thing!
roflwaffle (02-19-2011)
Old 11-04-2010, 07:19 PM   #4 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Nice job on the TDI swap
That would be fun for my car, but not worth the work, or would it be....
Old 11-04-2010, 07:32 PM   #5 (permalink)
Thanks! Part of the beauty of this car is that I DID do it, and learned a great deal along the way in surmounting all the technical challenges that it posed. The really neat thing about a car like this is that I'm free to experiment on it without worrying that I will screw something up, like I normally would when tinkering on a really nice car :-)
Old 11-04-2010, 07:49 PM   #6 (permalink)
Wiki Mod
That is the fun part. I think I would be to scared to try this on my car I have no where near this skill yet.
Old 11-07-2010, 10:55 AM   #7 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Craig, I like the flush headlight mod, it cleans up the front end a little. I read through your swap on TDIclub. Awesome build! As we go into winter I think you will find you can really close up a lot of the grill opening on a diesel and it will be happier. The block heater helps too. Does your engine have the cast magnesium oil pan? You may want to consider fabbing up a belly pan. It helps aerodynamics and may save your engine (and helps keep it warmer in winter and protect it from grime) A coroplast belly pan from the cat back really helped my highway mileage.
Welcome to Ecomodder, it's nice to have someone with your build skills on this site.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 11-14-2010, 07:01 PM   #8 (permalink)
Thanks! I'll have to try the belly pan, although I have a steel oil pan ('97 AHU) on my motor. I did snag a large coroplast political sign the other day for such a project, I just need the time to do it! I also bought a pair of 3" round convex mirrors so I can remove the outside rearview mirrors, so that's another project to do whenever I can squeeze it in.
BTW, I just filled up the other day and got 58 mpg! The actual figure was 57.9807, but 58 has a better ring to it :-) I'm heading to Mont Vernon, NH for Thanksgiving dinner, so I'm keen to find out what I will get for fuel mileage on a long trip.
Old 12-04-2010, 09:50 PM   #9 (permalink)
Just a quick update: best mpg to date is 58.46 mpg, although I didn't get to drive it to Mont Vernon...I created a fuel leak while adjusting the injector pump, so the car was sidelined for a week while awaiting an injector pump gasket kit. But it's all fixed now, at least until I screw something else up. While the car was down, I swapped out the side view mirrors for the round convex ones mounted inside the car; not sure how much of a measurable gain I will see, but every little bit helps.
Old 12-05-2010, 01:25 AM   #10 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Craig -
Amazing. Are there any MPG-Race competitions near you? It would be cool to see the "STDI" among its peers.
CarloSW2
900 Mile tank on Jetta TDI JSMITH8505 Success Stories 30 03-31-2015 12:16 AM
Saturn TDI Craig Introductions 29 05-26-2012 07:43 PM
PD tdi (volkswagen/skoda/seat) hints and tips 320touring EcoModding Central 58 12-14-2010 11:25 AM
FS Silver TDI Corrado with Black Leather 100% Diesel Conversion with Origninal Paint G60ING For Sale 8 03-09-2009 12:34 AM
Nose job for 1999 Honda CRV Xringer Aerodynamics 16 07-24-2008 11:47 AM
