Old 12-07-2010, 02:54 PM   #1 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 53.2 mpg (US)
Diesels and EGR
I have been reading up on EGR and mpg and it seems to help in gasoline engines. It makes the engine act like a smaller engine and reduces pumping losses. There is less vacuum working against the throttle plate so the engine is more efficient at part throttle. A diesel doesn't have a conventional throttle plate so does EGR help mpg or efficiency on a diesel??
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 12-07-2010, 03:17 PM   #2 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I know two people with TDIs. One of them disabled the EGR. He hasn't had any change in mileage that I'm aware of. I get paid to clean out the other guy's intake manifold. It's not hard to temporarily disable the EGR to test the MPG difference. But you will increase the NOx emissions and get a check engine light.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 12-07-2010, 04:09 PM   #3 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
Thanks Gas Fumes, Do you still have to clean the intake manifold since low sulpher diesel? My car is a 2004 PD with the O2 sensor. I have been told that my car won't run very well with EGR blocked unless I reprogram the computer.
TDi=fast frugal fun
Old 12-07-2010, 05:14 PM   #4 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
When I ran with disabled EGR in my TDI (with CEL set) it made no significant difference in economy. However it made a huge improvement (about 10%!) in the fuel economy of my Jeep CRD, and that has a modification that tricks the ECU so it doesn't set a CEL.
So I am working on the same device for my TDI and will document any differences here when I do that.
I'm not coasting, I'm shifting slowly.
Old 12-07-2010, 06:17 PM   #5 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
It varies from engine to engine.
Doesn't seem to help VW TDI engines.
It helps Ford 6.0 and 6.4 engines a lot as it does the Cummins 24 valve.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 12-07-2010, 11:11 PM   #6 (permalink)
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Subaru Legacy Wagon 2.5 GT
Subaru
90 day: 21.16 mpg (US)
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 53.91 mpg (US)
Olga - '03 Volkswagen Jetta Wagon
90 day: 46.24 mpg (US)
Originally Posted by Gasoline Fumes View Post
... But you will increase the NOx emissions and get a check engine light.
My understanding is that you will bump the NOx emissions quite a bit if disabling the EGR on the diesel ... cat can't handle the higher NOx emissions (whereas it can handle the other emissions much better) ... and the NOx is the nasty of the possible emissions (responsible for acid rain, ozone (smog) creation, health probs, etc etc).
Old 12-08-2010, 12:19 AM   #7 (permalink)
UFO
UFO's Avatar
The catalytic converter on most diesels is an oxidation catalyst and is not designed to deal with NOx. Disabling the EGR will have no effect on the cat.
Old 12-08-2010, 12:53 AM   #8 (permalink)
NightKnight
Subaru
Diesel
Ah, OK... so then the higher NOx emissions would just pass right through into the atmosphere?
Old 12-08-2010, 07:19 AM   #9 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
It wasn't long ago that I cleaned it and he had it cleaned by somebody else a couple of years before that. He's running WVO most of the time too. Still gets clogged with a black sooty tar. It's a 1999.5 TDI. The other one with the EGR disabled is a 2002 TDI running on diesel only.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 12-08-2010, 09:02 AM   #10 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
They put cats on diesels now?
What next, spraying pee pee into the exhaust?
On a TDI I believe you can reprogram the computer to use the EGR when cold but close it off when warmed up. Seems Fred's TDI Page. TDIClub.com. VW TDI Enthusiast Community had a tutorial on this. TDI FAQ
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
Cooled EGR Piwoslaw EcoModding Central 51 05-08-2015 04:30 AM
How do you eco-drive a diesel ? groar Hypermiling / EcoDriver's Ed 122 05-24-2014 09:05 PM
Theory: not just disabled cylinders, but a power/compound cylinder engine mechman600 EcoModding Central 18 04-16-2010 07:02 PM
EGR dilution for more MPG? cfg83 EcoModding Central 18 04-29-2008 09:11 PM
News: Only 6% of Americans think diesel will succeed as powertrain option MetroMPG General Efficiency Discussion 38 02-14-2008 02:23 AM
