Old 06-18-2009, 08:11 PM   #1 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
Turtle Attaching Wheel Covers - To drill or not to drill?
I am going to make wheel covers very soon.
I might use coroplast or pizza plates (undecided)
I read about people using fasteners, tape, screws, zip ties and magnets.
I was thinking about tapping the rim using screws in 3 spots to keep the covers on evenly.
Here is the picture of the rim Im using.
Its pretty flat once I remove the center cap.
Tap sites are in green.
Any dos/donts to drilling into a rim? Suggestions on which screws to use?
Past Present Future?
Old 06-18-2009, 08:21 PM   #2 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
I'd try anything else before drilling. zip tie them on to see what gains you'll get. Maybe it might not be worth doing at all.
But fixing the wheel covers on with bolts would be the most secure. Drilling into the spokes would weaken them. By a small amount yes, but......
ollie
Old 06-19-2009, 12:20 AM   #3 (permalink)
Your wheel is already flat. All you need to do is cover the gaps with tape. Why bother to make a cover and drill holes?
Old 06-19-2009, 12:23 AM   #4 (permalink)
Grasshopper
Mostly to keep it looking clean
I get enough looks from my inlaws as is
Providing the tests come back good, should I drill?
and...
If I want to use tape, which tape is best?
Old 06-19-2009, 02:38 AM   #5 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
No drilling... use PC7 Epoxy, and epoxy some threaded stand-offs in the deep places around your rim, then get it re-balanced with the hardware installed. This will keep your original rim integrity, not damage anything (except the finish, maybe), and allow you to remove them later if you wish, without permanent effects to the wheels.
Old 06-19-2009, 01:30 PM   #6 (permalink)
chuckm's Avatar
Exploder - '02 Ford Explorer xlt
Rolla - '02 Toyota Corolla ce
90 day: 44.43 mpg (US)
Since I have cheap plastic hub caps, I drilled and attached my pizza pans with pop rivets.
"Jesus didn't bring 'Natty Lite' to the party. He brought the good stuff."
Old 06-19-2009, 05:34 PM   #7 (permalink)
and...
Packing tape would be pretty inconspicuous. Aluminum tape that they sell for gutters and stuff like that would also blend in
Old 06-19-2009, 10:23 PM   #8 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Drilling into decorative plastic covers is fine, but do not drill into structural members that are subjected to millions of cycles of loading. A drilled hole creates a stress concentration that opens the door to fatigue failure.
Old 06-19-2009, 10:53 PM   #9 (permalink)
Grasshopper
This is a good idea which I havent seen much of. I will most def keep it in mind.
Tape might win on this one. Bleh
Cheap-o Smooth Wheel Covers bennelson Aerodynamics 40 03-15-2009 11:55 PM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 04:50 AM
wheel covers: corugated plastic or taped hubcaps? modmonster Aerodynamics 4 02-08-2009 07:54 PM
Universal Flat wheel Covers trikkonceptz EcoModding Central 14 06-28-2008 11:29 PM
Modded wheel covers to make them smooth MetroMPG Aerodynamics 1 11-27-2007 08:43 PM
