08-21-2020, 10:32 AM
#41 (permalink)
CAUTION : wrong Cd attributions!
Originally Posted by California98Civic
I honestly don't think so:
Though perhaps a little depends on how high your vertical plexiglass plate rises from the trailing edge of the trunk lid?
james
None of those drag coefficients are correct. They're all based upon sub-critical Reynolds number.
I'm all for an unrestricted internet, but there is a place for peer-review.
Do NOT use these values for engineering purposes!!!!!!!!!!!!!!!!!!!!!!!!!!
08-22-2020, 09:09 PM
#42 (permalink)
Cyborg ECU
Hahaha!
Aerohead, when I saw my profile associated with that, I thought I had been hacked. It is from 7 years ago! And i think you maybe forgot you already responded to it in this thread exactly like this, back in 2013? Here: https://ecomodder.com/forum/showthre...tml#post365364
No problem. Thx.
07-20-2023, 04:59 PM
#43 (permalink)
Mechanical engineer
The Following 2 Users Say Thank You to Vekke For This Useful Post:
07-20-2023, 10:31 PM
#44 (permalink)
I don't think there is a current CFD thread so I'll drop this here:
BEST Features in Blender 3.6 in LESS than FIVE Minutes! at 2"22
I don't see a CFD solution in Blender yet; but the new Simulation Node editor creates a framework with supporting data structures (OpenVDB) to enable that. Much like creating AI prompts, the design of node trees is non-trivial.
So, 3.6 extends functionality in the node editor with something called Implicit Sharing. Instance on Points
Instance to Points
Points to Vertices
Mesh to Points ....are all ten times faster. This is on top of loading meshes, point clouds and volumes also 10x. https://youtu.be/rRK4-k-4hRU?t=51
...these new simulation
nodes are pivotal new feature that give
artists the power to create Dynamic
simulations within geometry nodes with
the simulation input and output nodes
simulations will evolve frame by frame
creating incredibly intricate and
real-time visual effects and you keep
your workflow streamlined all the
simulation results can be baked or
cached with the new panel in the physics
tabs
Above my pay grade, but with Free and Open Source software one person's algorithm can spread to the hive mind.
..Without freedom of speech we wouldn't know who all the idiots are. -- anonymous poster
..Make the best use of what is in your power, and take the rest as it happens. -- Epictetus
07-23-2023, 03:46 PM
#45 (permalink)
That was then. Today I found this: youtu.be/tgWlTesKQ4U?t=420. (t=420  )
Why i there a low-pressure area at the stagnation point? aerohead?
07-24-2023, 02:53 PM
#46 (permalink)
Well, it's another day and the desired result inches closer.
Here is a simulation of gravity with little cubic raindrops. Particle and Collision Simulations in Geometry Nodes Blender 3.5 | Tutorial
The nodes build-up includes finding the reflection angle of a normal and other useful bits. The physics engine includes wind as well as gravity so It should translate from falling drops to horizontal streamers.
I should try this. Unfortunately, we're in paint drying season so I'm trying to take advantage of that.
07-31-2023, 10:12 AM
#47 (permalink)
'why'
It appears that there's no depiction of centerline flow. Everything is towards the 'camera' position, so it would all be accelerating within the Prandtl surface of discontinuity, or around the actual body. In this context you wouldn't see the 'colors' associated with static pressure & velocity pressure @ infinity.
