Old 08-11-2010, 05:18 PM   #1 (permalink)
The Cuttlefish - '06 VW Golf TDI
Most important ScanGauge variables?
Newbie here. I've had a scangauge for a little while now and have so far focused mainly on the MPG and AVG variables. Which other variables are the most important to keep an eye on in terms of maximizing efficiency, and why? I've basically got one open slot on my display, since I also monitor temperature closely in relation to my grille block. I've seen scattered references to the importance of watching engine load and intake manifold pressure, but I'm a bit unclear on which factor is best to be getting constant feedback on... What do you guys monitor most closely?
Old 08-11-2010, 05:23 PM   #2 (permalink)
Cevic - '09 Honda Civic DX-G, coupe
90 day: 39.79 mpg (US)
I personally use the LOD (engine load %) gauge a lot. It tells me how much to push on the throttle to get optimal acceleration, without wasting too much gas.
Old 08-11-2010, 05:36 PM   #3 (permalink)
LOD is important, but not really as important for a diesel engine I don't think. All the BSFC maps I've seen for diesels show that full throttle is always best, period. Hopefully Tas or someone else who knows diesels will chime in.
It really all depends on what you are doing as to what gauges you watch. I watch coolant temp because I have a full grill block on the car and I want to see how fast I'm heating up. I also watch 12V since I run a disabled alternator most of the time. However, both of these are useless to people who don't have those mods done.
Old 08-12-2010, 06:01 AM   #4 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
What are your 4 favorite ScanGauge Gauges?
The Following User Says Thank You to Piwoslaw For This Useful Post:
matthew (08-12-2010)
Old 08-12-2010, 11:12 AM   #5 (permalink)
oldschool
Olympiadis's Avatar
White2003Focus - '03 Ford Focus SE 4-door sedan
Team Ford
90 day: 38.53 mpg (US)
White2001S10pickup - '01 Chevy S10 extended cab LR
Last 3: 24.51 mpg (US)
1989DodgeOMNI - '89 Dodge Omni
Last 3: 30.38 mpg (US)
1991ChevyC1500pickup - '91 Chevy C1500
Last 3: 24.03 mpg (US)
White1986Irocz - '86 Chevy Irocz LB9
Last 3: 30.14 mpg (US)
1999 C5 Corvette - '99 Chevy Corvette
2008 Infinity G37 - '08 Infinity G37
I find the Horsepower and Gallons-Per-Hour gauges to be most helpful.
They both help in determining the most efficient amount of throttle to maintain a given speed.
GPH is handy for monitoring the fuel usage while coasting or idling.
Old 08-13-2010, 11:18 AM   #6 (permalink)
Thanks Daox, very interesting. I wasn't familiar with BSFC maps but looked around and found this one here that probably pretty close to my TDI:
Image:Vw tdi alh 99.5-03 bsfc.jpg - EcoModder
I'm struggling a bit to fully wrap my head around what the implications of these maps are for actual driving tactics. I keep trying to come up with a scenario that properly explains the way this translates to shift points, acceleration, hills, etc, but then I get tripped up. Would somebody be willing to elucidate? Thanks!
Old 08-13-2010, 12:04 PM   #7 (permalink)
It basically means when you accelerate you want to floor the gas pedal, and to shift to keep your rpms centered around 1750.
Old 08-13-2010, 01:15 PM   #8 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
mathew -
After I made this post :
http://ecomodder.com/forum/187883-post20.html
I came to the conclusion that these are the most important parameters for deriving MPG :
MAP
IAT
RPM
MPH
However, you always have MPH and you usually have RPM "for free" on your instrument cluster. For observation in the ScanGauge, I would look at these instant parameters :
MPG
MAP
LOD
IGN
If I had only one open slot like you are stating, I would pick MAP first and LOD second.
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
matthew (08-16-2010)
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 02:36 PM
Scangauge 2: monitoring hp on an Ion manderson99 Instrumentation 5 06-08-2010 11:05 AM
Dealer says ScanGauge ruined my PCM and I can't use ScanGauge anymore Markmysite EcoModding Central 55 05-06-2010 06:31 AM
Scangauge 1 - Some help please! jdubbs_scort Instrumentation 6 06-17-2008 03:26 PM
