Old 03-02-2014, 04:57 PM   #1 (permalink)
Supra - '88 Toyota Supra
superhawk - '98 Honda superhawk
Last 3: 27.62 mpg (US)
Lesabre - '96 buick lesabre
3800
90 day: 25.85 mpg (US)
Saturn - '97 Saturn Sc2
Team Saturn
Sports Cars
90 day: 39.12 mpg (US)
Truk - '99 Ford F150
Team Ford
Pickups
90 day: 24.43 mpg (US)
Golf - '03 Vw Golf
90 day: 38.57 mpg (US)
98 Superhawk
I have a 98 honda superhawk and want to get better fuel mileage without ruining the way it looks so I want to start by changing the rear sprocket.
I have already gone from a 16 to 17 tooth sprocket on the front and put on a 39 from the stock 41 but can't find anything smaller any ideas?
Thanks
Jon
Old 03-02-2014, 05:13 PM   #2 (permalink)
I think that may be about it.
A 1000cc twin is only going to do so well in the MPG department no matter what you do. If you really want good numbers sell it and buy a CBR250R.
Otherwise just have fun with it.
Old 03-02-2014, 05:46 PM   #3 (permalink)
3800
Team Saturn
Sports Cars
Team Ford
Pickups
Golf - '03 Vw Golf
I enjoy my big vtwin too much to ride anything else but I know the engine could be spinning allot slower and still pull hills good and i can always downshift if it doesn't. I would like to get down to 30 teeth on the rear
Old 03-02-2014, 06:37 PM   #4 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
I had a '97 Superhawk. Awful awful awful on fuel. A tiny fuel tank doesn't help for range. All I can say is good luck.
Gear it WAY higher and try to keep the revs very low, relying on the gobs of torque it has to spare. Very very difficult to do, considering how amazing that engine sounds at high revs!
Old 03-02-2014, 07:29 PM   #5 (permalink)
VT1000f made my short list, but the little tank nixed it for me as well. Narrowed down to used FZ1 or new Bandit 1100. FZ1 won for me. Nephew had a SV1000 fun ride, not a lot to do with your Hawk, don't worry about the gearing, look for good deals on tires, they cost about as much per mile as gas. And insurance.
Old 03-09-2014, 05:15 PM   #6 (permalink)
I took a quick look at JT sprockets website on your behalf, there is an 18 tooth front sprocket available which has the same fitting dimensions as the superhawk, catalogue number JTF 339. I can't say for sure if there will be enough clearance for the larger sprocket, JTS are very helpful it might be worth asking their advice.
Regards,
Ironside.
Old 03-11-2014, 05:51 PM   #7 (permalink)
American Viking's Avatar
Dad's Jetta - '05 Volkswagen Jetta 2.5l package one
90 day: 23.23 mpg (US)
Black Cherry - '01 Honda VFR800fi
Last 3: 39.39 mpg (US)
Regards,
Ironside.
If the 18 will fit without hitting the cases or the guides, I'd go with that.
16/41 is a 2.563
17/39 is a 2.294 or 11% less revs
18/39 is a 2.167 or 18% less revs
If you want more efficiency, than that, you'll have to re-jet and/or downsize the carbs.
Then the only thing you can really do after that is reduce friction and weight (both rotating and non-rotating).
This would be a good bike to consider - Ecotrons EFI conversions on it. Probably could use the EFI Throttle Bodies off an RC51.
JohnS
Black Cherry (no epa ratings)
Dad's Taxi
The Lead Sled (EV conversion coming soon)
Old 03-11-2014, 08:40 PM   #8 (permalink)
16/41 is a 2.563
Or you could just get something that started off getting big numbers - like a CBR250.
You will never overcome that much more displacement/power than is required to propel a typical motorcycle at a moderate speed.
Just have fun with it, because there's really no reasonable way to make it get seriously high MPG numbers.
Old 03-11-2014, 09:33 PM   #9 (permalink)
Some of us would kill a cbr250 and don't want to just buy a new or another bike.. I can add my luggage to a Superhawk and still go touring on it, much like with my VFR.
That's not something I can do with a cbr250.
The OP already has a Superhawk and is not chomping at the bit for another bike, so why not make useful suggestions.
I'd bet that with the right parts you can get descent mileage from it.
Sure its a large-ish V-twin, but that doesn't meant it can't operate more efficiently than it did when it left Honda's factory.
JohnS
Dad's Taxi
Old 03-11-2014, 09:43 PM   #10 (permalink)
He didn't say he wanted to add luggage and go touring, he said he wanted better mileage. If mileage is a concern, riding a BIG (1000cc) V-Twin isn't a great choice.
Getting into major mods like you suggested in order to get slightly better mileage from a 1000cc motorcycle is not a useful suggestion.
I think my comment of "just ride it and have fun" is a useful suggestion.
