Old 04-03-2010, 08:49 PM   #1 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
MPG calculation with non-stock tire size?
I'm not sure how to calculate miles driven with a non-stock tire size. I can't remember if you multiply the miles driven to the % difference in speedometer reading, or what.
Thanks in advance!
In Reason we Trust
Old 04-03-2010, 08:54 PM   #2 (permalink)
Yes, you need to calibrate the odometer (by driving a marked distance on the highway, or measuring it with GPS, or measuring it in GoogleMaps) and then adjust the odometer reading by a percentage to correct it.
Old 04-03-2010, 09:24 PM   #3 (permalink)
AeroModder's Avatar
Team Ford
Alright. The new tires I'm getting will cause the speedo to be 2.3% slower, according to this: Wheel-Tire - WWW.RIMSNTIRES.COM size comparer&sw1=185&ar1=70&bd1=14&rw1=6.5&et1=45&sw2= 195&ar2=70&bd2=14&rw2=6.5&et2=45&text1=&text2=
Can I use that percent, or will the odometer reading be changed by a different percent so I have to go a set distance and compare?
In Reason we Trust
Old 04-03-2010, 09:39 PM   #4 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
AeroModder -
I use tire calculators and then I cross-reference my odometer trip meter against a GPS :
http://ecomodder.com/forum/showthrea...ires-2642.html
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
AeroModder (04-03-2010)
Old 04-03-2010, 09:51 PM   #5 (permalink)
AeroModder's Avatar
Team Ford
Thanks for the info, but I don't have a GPS to go by, and can't afford one, especially after ordering the new tires. ^^;
But from reading that, it looks like the percentages for the speedo and odometer are the same.
So, if I'm not mistaken, the formula would be:
Distance reading x % correction = Distance error
Distance error + Distance reading = True distance
And in my case it would be about:
250x0.02=5
5+250=255
Is that right?
In Reason we Trust
Old 04-03-2010, 10:16 PM   #6 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
AeroModder -
Yup, that's what I do.
My tires account for a +2% "bonus" when I fill-up. To keep track of what is going on, this is my typical "Details" section of my Fuel Log :
193217 miles on odometer. Tires are larger, so odometer is reading 2% less, hence +2% correction: 246.4 * 1.02 = 251.328
Maybe you can find a pal with a GPS that you can borrow. Hiker dudes usually invest in them. You usually only need about 20+ miles to get a good reading. I put the GPS on my dashboard to make sure it doesn't lose access to satellites, and shoot for long straight lines (i.e. freeways). I am sure it works fine on curvy roads, but I also think that will introduce a tad more error.
CarloSW2
Old 04-03-2010, 10:33 PM   #7 (permalink)
AeroModder's Avatar
Team Ford
Sweet. Thanks for the help! ^^
In Reason we Trust
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 276 03-14-2022 03:51 AM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 09:25 PM
change in tire size mully General Efficiency Discussion 8 09-28-2008 08:13 AM
Tire Size Improvements Blue07CivicEX EcoModding Central 11 07-25-2008 02:44 PM
Correcting for tire size whokilledthejams EcoModding Central 15 07-22-2008 07:16 PM
