Old 04-10-2009, 05:06 PM   #1 (permalink)
MPGuino Parts list
I pulled the partslist out of the release one thread, and its the only listing I have found that seems to be "here you go, buy this" and then i found issues.
list source : http://ecomodder.com/forum/showthrea...pace-2115.html
Arduino - going to get an actual one because i could only find the idunio for 20+45 shipping
list
2 5.1v zener diodes - 5.1v Zener diode
what wattage?
1 2n3906 PNP Transistor - 2n3906
i was just going to get the first one
1 220 ohm resistor - 220 resistor
found several, but what wattage
2 100k resistors - 100k resistor
see above
3 tactile switches
- SWT6-V3RD
probably just 3 of these
thanks for your help with the recomended wattages
Old 04-10-2009, 11:04 PM   #2 (permalink)
EcoModding EcoModder
wikityler's Avatar
Gerald - '91 Pontiac Firefly 3dr
90 day: 40.08 mpg (US)
The resistors and diodes are being used in a signal function not power, so almost any wattage will do. 1/4W resistors are the most common. A 1/2W diode will be fine. The first PNP will be fine, as will those switches.
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
List of Low Rolling Resistance Tires Daox EcoModding Central 57 05-13-2019 01:17 AM
Places to get OEM Honda Parts TomO Off-Topic Tech 10 06-02-2009 01:56 PM
