07-15-2008, 01:47 PM
#431 (permalink)
Dartmouth 2010
So if the MPGuino is only showing about 1/5th of the distance, I should convert my 8204 number to 1640?
07-15-2008, 01:58 PM
#432 (permalink)
needs more cowbell
No, well yes, but no!!  Something is wrong if it is 1/5.
Can you put a voltmeter on the mpguino to car vss connection and turn on the ignition then roll the car slightly till it reads 12 volts? Then measure the voltage on analog 0?
07-15-2008, 02:01 PM
#433 (permalink)
Dartmouth 2010
Yoink! I'll solder everything up tidy and do that. Post back in a bit.
07-15-2008, 02:06 PM
#434 (permalink)
needs more cowbell
Ok, I wasn't asking to resolder everything, just to measure the voltages with it in the car. Of course you may have reasons to believe that resoldering is necessary that I am unaware of. Make sure your Zeners in in the right way too.
07-15-2008, 02:20 PM
#435 (permalink)
Dartmouth 2010
Well, I was soldering them cuz I just had them twisted together by hand and exposed, and now that I know I have the connections proper, I thought I should solder them and be done with it.
Anyway, I got voltage 10.8 at the vss and 3.7 on the analog pin
07-15-2008, 02:30 PM
#436 (permalink)
needs more cowbell
Ok, 3.7 is pretty solid. Can you do continuity from a duino ground pin to vehicle ground?
07-15-2008, 02:41 PM
#437 (permalink)
Dartmouth 2010
Ground is fine, but the vss setting on the mpguino was way off. I know I reset it to 8204 for perhaps that setting was lost. I reset it again, keyed off, and it stayed at 8204...I'm going out soon so I guess we'll see.
07-15-2008, 02:43 PM
#438 (permalink)
needs more cowbell
You are getting mpguino power from the battery and not the ignition, right? The atmega does not like bouncy power in the least. You might need to reflash it if it isn't happy yet.
07-15-2008, 02:59 PM
#439 (permalink)
Dartmouth 2010
I'm getting the power from one of the power draw spot on my underdash fuse box. We shall see if it works of if I need to move the source.
07-15-2008, 09:44 PM
#440 (permalink)
Dartmouth 2010
Hey all, the 8204 number is pretty much spot on...
Now I wonder about the fuel value. I used andrew's since the vx and cx have the same injectors (or so they say), but I was wondering if anyone has calibrated on a VX?
Thankee
