Old 10-26-2011, 01:03 AM   #1 (permalink)
JJMunoz's Avatar
Seriously? II - '02 Honda` Insight
90 day: 67.94 mpg (US)
Endearing Fuel Gulping Box - '08 Honda Element EX
90 day: 32.18 mpg (US)
MPGuino Values lost after powered down?
Hey guys.
I hooked up the MPGuino in my 94 Civic DX today and I noticed something about it which is problematic.
I incorporated a power switch in the circuit so that the MPGuino doesn't have to be on when the car is off and parked.
However, when I turn the power off I lose my Tank miles and distance.
My U/Sec and VSS Pulse figures remain saved though.
Any way to fix this?
Or does everyone else leave their MPGuinos powered on all the time?
Thanks.
JJ
Old 10-26-2011, 01:17 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
mine is on, always, about 20milliamps idle. The backlight turns off after 7 minutes of no activity. It keeps the setup parameters in eprom, but the trips are in ram for speed/accuracy.
The Following 2 Users Say Thank You to dcb For This Useful Post:
JJMunoz (10-26-2011), razor02097 (01-25-2013)
Old 10-26-2011, 01:48 AM   #3 (permalink)
JJMunoz's Avatar
Awesome! Thank you!
Old 10-26-2011, 03:29 AM   #4 (permalink)
meelis11's Avatar
Green frog - '97 Audi A4 Avant 1.9TDI 81kW
Diesel
90 day: 43.1 mpg (US)
In wiki section there is code how to save tank parameters to eeprom - so you dont lose them if you want to disconnect mpguino sometimes or you get power loss.
I made some changes to my code so mpguino goes to sleep and consumes around 5-6 milliAmps. If someone is interested, I can check code and put that part here or in the wiki. It was quite easy actually, just added one line into that block where backlight is turned off.
