Old 06-12-2009, 12:02 AM   #1 (permalink)
Multi-Parallel Battery Charge
Hi all: Could someone shed some light on my idea of charging a chain of batteries while still connected to the load..?
I mean this:
|--12V Charger--| |--12V Charger| |--12V Charger--|
|------Battery-----------Battery------------Battery----|
|---------------LIVE LOAD DC Motor-------------------|
Do you think it may work? Anyone foresee any reasons why I should not try that?
There would be all LifePo4 Cells in series nearly up to 100V, and multiple 12V alternators..
any thoughts on this are appreciated
Thanks,
TechieatWork
Old 06-12-2009, 01:10 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
The first question that comes to mind is "Why?". If you have a load and you have a power outlet, why cycle the batteries? Isolate them and charge them if needed, but ???
Old 06-12-2009, 01:35 AM   #3 (permalink)
thanks dcb for the reply.
the main reason is: I wanna go completely off grid.. In normal petrol cars, alternators re-charge the single battery.. for my setup I will need multiple batteries and the mega mamoth DC motor (the load).. I am contemplating recharging with generators similar to the ones used in solar installations.. each generator for each block of 12V cells
I hope I am making sense..
Old 06-12-2009, 08:54 AM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
There's not enough specifics to really say much here.
Old 06-13-2009, 03:41 AM   #5 (permalink)
what kind of generators?
EV59rag
Parting out my EV.
ES-31C D&D Motor
Alltrax 7245 Controller
Paul & Sabrina's Controller (never used)
Old 06-18-2009, 12:57 AM   #6 (permalink)
I found the answer already here:
S10 EV Wiring Diagrams
what kind of generators? one like this:
Regeneration Braking!
or even better.. one like this:
Polyphase Motor/Generator Page
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 49 07-06-2014 10:27 PM
can you use a DC motor controller to charge car battery from a higher voltage battery modmonster EcoModding Central 9 02-13-2009 07:14 PM
Battery Post Repair bennelson Fossil Fuel Free 4 10-17-2008 03:35 AM
parallel battery pack question Daox Fossil Fuel Free 8 09-24-2008 03:17 PM
Correct battery voltage ? groar Off-Topic Tech 2 09-23-2008 09:13 PM
