Old 01-23-2020, 01:38 AM   #51 (permalink)
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
I had old RE92s do that on me. You notice it on the road; you've got a few miles before they totally die.
Old 01-23-2020, 03:06 AM   #52 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I never noticed anything while driving on it, but the tires have been off the car for almost two months. If a tire blows up in a basement and no one is around to hear it, does it make a sound?
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 01-23-2020, 06:04 AM   #53 (permalink)
90 day: 55.9 mpg (US)
You only know when you observe. Schrödinger's RE92s.
Old 02-28-2020, 10:51 PM   #54 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
Oil Report
I had my oil tested. I'll ask if the 0w-16 oil could be causing the elevated copper levels. I used the same oil again. I don't do a lot of idling or short trips to explain the fuel, but the oil was drained cold.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 02-29-2020, 09:48 AM   #55 (permalink)
Just my opinion: what is made of copper inside your engine that gets an oil bath? There should be another metal with high readings unless you are eating up wire looms. Bronze is an alloy, tin levels are zero, but silicon is up unless your locale is dusty.
Gasoline Fumes (02-29-2020)
Old 02-29-2020, 02:40 PM   #56 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
I was thinking the same thing. Nothing in there is copper to my knowledge, maybe it's an additive of the oil itself?
Old 03-10-2020, 02:41 PM   #57 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
Not bad for mushy snow tires and heavy wheels! Max speed is not correct!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 03-10-2020, 03:15 PM   #58 (permalink)
Nice numbers! You're certainly beating me.
You've probably noticed but the scangauge doesn't read economy correctly when the car is in lean burn.
Old 03-10-2020, 04:24 PM   #59 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
I like how the SG doesn't see LB. I can tell how much of a difference LB makes!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 03-10-2020, 04:50 PM   #60 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
Nice numbers! I knew you'd be able to get your earlier numbers up.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
