Old 04-12-2011, 07:08 PM   #41 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
I wondered what they're called. Thanks.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 04-14-2011, 04:34 PM   #42 (permalink)
Originally Posted by Christ View Post
It doesn't, dave, and the coanda effect can never effect thrust, since that would require the addition of energy, something coanda doesn't do. Coanda's effect is that of direction change through utilization of nearly all of the existing energy. In the example I provided, coanda removes nearly all the kinetic energy given by gravity, until the flow of water reaches an exhaustion point, where gravity takes over again.
check this out
Old 04-14-2011, 05:23 PM   #43 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
remember what i said about the air around it not being entrained with it? put a fan above that thing blowing down so that the entire top surface has air blowing against it and it woun't do a darned thing
Old 04-14-2011, 05:56 PM   #44 (permalink)
mcmancuso's Avatar
Green Metro - '99 Chevrolet Metro LSi Sedan
90 day: 32.78 mpg (US)
Metro Vert - '91 Geo Metro LSi Convertible
90 day: 50.52 mpg (US)
There's energy to be had from working the air flow right, I mean look at this insanity here:
Wind-Powered Car Travels Downwind Faster Than the Wind | Autopia | Wired.com
Old 04-14-2011, 06:01 PM   #45 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
The air traveling is more than likely responsible for any thrust created there. He's using a vacuum cleaner.
Old 04-14-2011, 09:03 PM   #46 (permalink)
the fan actualy blows towards the bowl, its counterintuitive but thats how it works
Old 04-14-2011, 11:39 PM   #47 (permalink)
Where is the air being taken from? Cant be from behind the salad bowl... that would weaken the effect drastically. So itsbeing taken from infront the salad bowl and the fan is spreading it over the surface of the salad bowl, where the coanda effect DOES NOT effect thrust, it simply spreads the lower pressure. Over a larger area, allowing the vacuum motor's energy to.be better utilized... it isnt coanda that created the thrust... the vacuum motor pulling air.creates thrust. The salad bo..erm... coanda device just distributes the.pressure difference over a larger surface.area by using part of the existing energy, which had already been transferred from electrical to rotational, then to pressure differential. Seems like a pretty inefficient process to me, when the electric motor driving that fan could have been used.to.directly power those wheels...
Old 04-20-2011, 01:18 PM   #48 (permalink)
over the weekend i changed the front ones with some bigger ones,
yesterday i got on the highway (up to 70 mph)for about 20 miles, when i got home i checked the devices and they were both really loose,
i take that as a good thing, since they are taped down with some realy good wide tape,
i would say it would take at least around 10 pounds of force to loosen that tape
im pretty sure the looseness comes from the air alone, since i didnt drive trough gravel or bumps or anything like that
but the main thing is how the car feels, the most noticeable is the rolling distance which has increased quite a bit
Old 04-20-2011, 01:21 PM   #49 (permalink)
Gonna have to see some data, gabi.. Measurements of distance, at least semi-controlled tests, etc. Otherwise, you're just putting words in a database, friend.
Old 04-20-2011, 01:43 PM   #50 (permalink)
im not sure im good at producing data, i know it works for me
if somebody wants to pick it up and produce some data that would be great, its a simple fast mod
besides i'm not trying to sell anything,or convince anybody, just sharing my experience
