Old 04-21-2012, 09:02 PM   #11 (permalink)
low&slow's Avatar
l&s' Jag - '00 Jaguar S-Type SE
90 day: 25.86 mpg (US)
l&s' Vision - '82 Yamaha Vision XZ550RJ
90 day: 59.92 mpg (US)
L&S' Greenaero Ninja 250 - '99 Kawasaki Ninja EX250F Ninja 250R
90 day: 97.24 mpg (US)
SilverAero Ninja 250 - '04 Kawasaki EX250 Ninja
90 day: 88.24 mpg (US)
Very impressive, well done
Old 04-28-2012, 04:56 AM   #12 (permalink)
Nice!
Old 05-04-2012, 01:40 PM   #13 (permalink)
90 day: 51.82 mpg (US)
One more time!
Second 100+ mpg trip!
101.2 MPG (US) / 2.33 L/100 km per the car's computer (FYI, it has been within a couple of percent accuracy at fill-up time)
Again, ideal conditions:
22 C / ~73 F ambient
very light breeze
dry, rural (empty) roads
80 km / 50.2 mile round-trip
38 mph trip average, including a small amount of sub/urban driving on either end
And, again, this was driving with the aim of keeping the thing in lean burn as much as possible, plus engine-off coasting to stops & turns.
That's too slow though. On the open (rural) road portion of the trip, I'm probably averaging ~45 mph.
It needs more aero mods so I can go faster and continue getting these results.
Old 04-25-2016, 11:38 AM   #14 (permalink)
He-man's Avatar
Rocket - '99 Chevrolet Corvette
90 day: 31.51 mpg (US)
Pooter - '01 Honda Insight
90 day: 66.9 mpg (US)
very light breeze
I know these are old numbers but it makes me wonder if the hybrid system actually helps at all. When i first bought my insight the hybrid system was not working and i was easily averaging over 70 mpg but when i fixed the system i had to struggle to get it to 60 mpg which i can't do currently averaging around 55 this gas tank.
Old 04-25-2016, 11:57 AM   #15 (permalink)
The answer is: it does help, but the Insight is already so efficient that in the hands of a dedicated hypermiler, it's still possible to get crazy good numbers without assist or regen.
(Meaning: lots of manual engine-off coasting, plus paying close attention to driving with load to maintain lean burn).
A typical driver would definitely see worse mileage without the hybrid functions.
I could see how an Insight with an ailing hybrid battery *could* get worse mileage if the system is frequently doing recalibration charging, which would drag the numbers down.
He-man (04-25-2016)
Old 04-27-2016, 11:13 AM   #16 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
For the most part, the hybrid system makes the Insight's 3 cylinder feel like a larger engine. 3cyl + IMA is certainly more efficient than a 4 cylinder, but the IMA actually does relatively little to improve efficiency directly.
There's autostop, and regenerative braking, but a dedicated hypermiler will conserve velocity and shut off the engine at stoplights anyway.
MetroMPG (04-27-2016)
Old 04-27-2016, 11:19 AM   #17 (permalink)
Yup.
In fact, the programming for autostop is fairly conservative. One of the first mods I did to mine was to add a kill switch so I could stop the engine more often, much sooner and at higher speeds than the car would have otherwise. That alone makes a big difference in mileage.
Old 04-27-2016, 11:23 AM   #18 (permalink)
This is going a bit off topic, but I find that, living in a very hilly area, I can't use EoC very frequently if I make use of electric assist, as it's necessary to maximize regen to keep the battery up. My HCH1 does a much better job of keeping the battery above 50%, with the same driving patterns.
Old 04-27-2016, 11:59 AM   #19 (permalink)
I rarely used assist in the Insight (clutch switch mod).
So you can power up the hills ICE-only, and auto-stop your way down the other side.
Yes, then it's like your turbocharger is offline.
Old 04-27-2016, 12:17 PM   #20 (permalink)
Indeed.
I live at the top of a hill with a dirt (often mud) road, and in parts I need to be in 2nd gear with full assist to get up, if things are muddy. After a 30 mile drive, I can often lose 10mpg just climbing the last hill to my house. So, in some cases, assist is not optional for me.
