Old 04-06-2010, 09:59 AM   #11 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Carnot's equation refers to the difference in temperature of the working gasses. A hot air intake could affect potential that way, but the radiator's job is to keep the machinery from self-destruction. Until the thermostat opens, it does not affect block temperatures. Because the water pump is centrifugal, pumping losses go down as the thermostat closes, but not as much as air drag can be reduced with a variable intake.
Old 04-06-2010, 09:59 AM   #12 (permalink)
Tracy - '00 vauxhall corsa
heat engines work by having a hot place and a cold place. the difference between the two temperatures determins the efficiency. i think on a car the hot place is the engine and the cold place is the atmosphere? or is it the radiator temperature?
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
DIY - Front Grill Block - 1991 Honda CRX SVOboy DIY / How-to 33 06-24-2011 05:16 PM
Grill Block question? chipX Aerodynamics 31 03-11-2009 03:47 PM
grill block and lean burn really working for me modmonster Success Stories 1 02-16-2009 05:07 PM
Active grill block idea holypaulie Aerodynamics 17 10-13-2008 09:31 AM
Grill Block Revision - Work in Progress Photos gascort Aerodynamics 15 07-10-2008 11:43 PM
