Old 12-30-2010, 12:20 AM   #1 (permalink)
How to get Ultragauge to recognize EOC?
How do you get an Ultraguage to recognize (i.e., not shut off) when you are engine off coasting? I'm experimenting with EOC in my new Ultragauge, and it turns off within a few seconds of when I turn the key to ACC. It doesn't come on again until I turn the engine back on, at which point, both the instantaneous and avg MPG fluctuate for a minute, suggesting the UG wasn't recording the extra distance I traveled without consuming fuel. I've read that when some kind of hybrid mode is engaged, the UG will either stay on or somehow understand that you're moving without fuel, and it will keep your Avg MPG and distance updated. How do I do this please? Thanks!
Old 12-30-2010, 12:45 PM   #2 (permalink)
Is there a "Hybrid" mode or engine setting? On a ScanGuage, that does the trick.
Old 12-30-2010, 07:25 PM   #3 (permalink)
I've been looking through the manual, but haven't found one. The closest I saw was an option for DFCO, and I don't know if that will have the desired effect.
Old 12-31-2010, 02:25 AM   #4 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
SG & UG both fail to record distance while the key is in the ACC position & you're EOC. I've noticed a difference of about .3 miles during a 10 mile loop when I'm P&Ging w/EOC, v. driving the same loop with cruise control.
One difference is when the SG is in hybrid mode, it displays instantaneous mpg during EOC. The UG doesn't display impg during EOC, but does record trip and average mpg parameters.
Another difference is the UG doesn't display trip average mpg during the first minute of total time the ignition key is on after the trip is reset. Instead, it displays a fluctuating impg in the trip avg mpg display space for that first minute when the key is on.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 12-31-2010, 03:42 PM   #5 (permalink)
Thanks for the information, SentraSE-R. It looks like it's just not an included feature. Oh well. At least I've got one now. I just started a fresh tank and am eager to see what I can do with this instantaneous feedback.
Old 01-21-2011, 12:10 AM   #6 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
I'm thinking you would have to find a way to enable power to the ECU with a switch/relay setup...
Old 01-21-2011, 03:28 PM   #7 (permalink)
Niner_xA - '05 Scion xA
90 day: 35.82 mpg (US)
Horse Hauler - '95 Ford F-250 XLT
90 day: 13.47 mpg (US)
Butterkup - '02 Mazda Miata
Yeah, I can validate the UG continues to collect data when I use my injector kill switch (which turns the engine off, but not the ECU). Unfortunately, it displays 0 instantaneous MPG, rather than 999, but I guess it's a matter of tastes (it's divide-by-zero handling).
Old 01-21-2011, 04:55 PM   #8 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
Isn't this the problem that was solved in a previous thread by installing a kill-switch to stop the engine instead of using the key?
The thread i'm thinking of.
