Old 07-14-2017, 12:25 PM   #71 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Spirited driving with the top down the whole time and...no real change to gas mileage! Thought all those unnecessary 5k+ rpm shifts would have killed it. Apparently not?
Old 07-14-2017, 12:34 PM   #72 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Yea I had mine up to 140mph once (down a 6% grade, mind you) and 130 another time my last tank. Didn't really seem to affect anything. Does seem to matter what I do to mine, stuck just below 30 haha.
Old 07-14-2017, 12:46 PM   #73 (permalink)
90 day: 38.47 mpg (US)
How does the Miata get such bad MPG for a tiny car?
Old 07-14-2017, 12:47 PM   #74 (permalink)
Super short gearing, bad aero.
Old 07-14-2017, 12:55 PM   #75 (permalink)
Stubby79's Avatar
bad aero.
That's why I expected my mileage to drop with the top down...expected it to make it even worse!
Old 07-14-2017, 04:38 PM   #76 (permalink)
90 day: 57.73 mpg (US)
Every time you update with new info, you gimme the Miata itch.
I'm going start repairing the my floor in mine around the end of the month. I'd like to have it on the road in August, and then aim for 40+ MPG on my next fill.
Too bad about Photobucket wrecking all the linked images in this thread.
Old 07-14-2017, 06:12 PM   #77 (permalink)
Furry Furfag
3750rpm at 75, and I have massive tires compared to stock. 205-50-15's vs I think stock is like 185-45-14. Not to mention they are extremely sticky tires.
I also run the AC about 50-75% of the time.
Old 07-14-2017, 06:28 PM   #78 (permalink)
How costly would it be for manufacturers to just add 1 more "cruise" gear for sporty cars to get good MPG?
My Acura suffers the same problem, and it has 6 speeds! The 6th isn't useful on the track because the car isn't powerful enough to ever get to a speed to use it, and it's pointless on the freeway because it revs way too high to get good MPG. My 6th is basically a waste.
Old 07-14-2017, 09:18 PM   #79 (permalink)
Furry Furfag
NB 6-speed with a 3.63 rear end is the best combo ever. 1-5 is the same ratio of 1-5 on the NA, and 6th is used as a 'cruising' gear. Eventually I'm going to upgrade, but the transmission is 600 and the rear end is 600-900.
Old 07-14-2017, 11:16 PM   #80 (permalink)
How costly would it be for manufacturers just add 1 more "cruise" gear for sporty cars to get good MPG?
If I had a nickel for every time I've said that...
