05-06-2020, 08:06 PM
#81 (permalink)
I had to provide proof my name was on the house. Otherwise had to pay cash for my solar.
Small areas inside California are nearing max solar capacity even with as few as 5% of homes having solar because everyone pointed their panels in the same direction for maximum overall production and in the middle of the day no one is cooking, charging thor tesla or doing laundry most days of the week so very little of the production is consumed by the home.
There's 2 ways to fix too much solar. Shut'em off which sucks, or have future installs favor morning or evening peak production.
So if the homes with solar are spread out over a wide area and not clumped together and their peak production all doesn't peak at the same time the power grid won't be flooded with too much solar.
Or power companies can get some battery storage capacity, which they really don't want to do.
That's only scratching the surface of problems created by intermittent power generation.
More solutions are possible but I have not seen anyone actually build them.
05-07-2020, 01:48 PM
#82 (permalink)
It's not simply a problem of storing excess power, it's generating more capacity than the lines and transformers are capable of safely handling.
Yesterday my system was able to reach peak (clipped) production at 6,000 W while my house was using 250 W. I was throwing 24x more energy into the grid than I needed myself. If a significant amount of homes do this, it's easy to see how infrastructure can become overloaded.
Yesterday I produced 25 kWh, or $2.75 in electricity. My utility bill is going to be somewhere around $12/mo from here on out. Another little perk I noticed is there are some city taxes on the net amount consumed, so with zero net use, I'll pay zero city tax.
Here's a portal to view my stats:
https://monitoringpublic.solaredge.c...2-311e68d5c4ce
05-07-2020, 06:01 PM
#83 (permalink)
Yeah mines going to be around $30 most months because of surcharge and then I will get slammed in January and February since my roof is sloped for optimal summer production and production will fall off a cliff in the middle of winter.
Just have to use the coal furnace more.
05-07-2020, 06:18 PM
#84 (permalink)
The way our utility net-meters, I bank overproduction for a year and then true up. Overproduction at true up is not compensated at all, and underproduction is billed at the normal $0.11/kWh rate. I'll make sure I come in right around zero. Might get difficult to do that once I get an EV.
05-08-2020, 12:30 AM
#85 (permalink)
Mine only goes monthly.
08-12-2022, 04:00 PM
#86 (permalink)
In 2020, I paid $70 in electricity and $144 in meter fees.
In 2021, I paid $296 in electricity (started mining Ethereum) and $144 in meter fees.
So far in 2022 I'm at break even, but I need to bank excess to get me through winter.
I added a chest freezer which is an extra 774 kWh per year, which really is about 3x more than a modern freezer would consume. I'm going to buy a new one...
Gone is my mining rig (at my parents house), but I added a video surveillance / media repository PC that runs ~100 watts. It's a bit overkill, but it was free.
My solar company found the cause of 1 of my panels not producing... stinkin squirrel
I cut back the branches near my roof, so hopefully that puts an end to critters up there.
08-12-2022, 04:18 PM
#87 (permalink)
Kill zem. Kills zem all.
12-22-2025, 03:02 AM
#88 (permalink)
Must not have cut the branches back enough, because now I'm at half output after squirrels got to the wires again.
For Christmas break, I'll be pulling panels and fixing wires if I can get a dry moment on the roof.
12-22-2025, 08:50 AM
#89 (permalink)
Projects With Everyday Dave is worth a look:
He's an engineer who does the research properly.
He's tested South-West vs South and vertical East-West etc-etc.
One eg:
Some very interesting results where he gets more power when you want it, like early morning and evening.
The vertical with reflectors experiment is interesting, in that plain old (crushed) limestone reflects 95% of light. Especially the frequencies solar panels like.
For the cold dark times:
Combined Heat and Power (CHP) is over 80% efficient!
NOTHING else is that efficient!!
(Works by pre-plumbing 'waste' heat into your existing heating systems, NOT replacing them.)
I keep mentioning it, but it seems to fall on deaf ears..?
I REALLY WISH people would say WHY they dont like the idea!?
Maintenance?
That's once every year and 2 months IF you run iit 24/7.
Combined with solar and batteries for the warm sunny times,
that works out to an oil change every what? 5-10 years..?
Or perhaps;
Avoid getting into a debate with some nut whose mind's already made up!??
