Old 09-16-2024, 03:24 PM   #131 (permalink)
Originally Posted by Logic View Post
I dont think the tracker was THE POINT oil pan:
The point was the fact that HEAT DECREASES EFFICIENCY and panel lifespan.
So what are easy ways to keep panels cool?
1st would be a decent sized gap between panels and roof or whatever so a breeze can get at the bottom.
IMHO 2nd would be well watered plants underneath and around as they evaporate water into the atmosphere and Evap cooling is the most efficient cooling you can get. That's why it's cooler under a tree than it is under a roof...
That all goes to hell in humid climates, so you could move to Zaire (or whatever its called this year) if you felt like taking a dump on some facts..?
Any of the panels I replaced or had to move all have bigger gaps now. For that reason.
Logic (02-09-2025)
Old 02-07-2025, 09:19 PM   #132 (permalink)
Man I had a $140 power bill. Time to expand the system. I got 6 of those 300w panels left.
I order 6 sunpower micro inverters for 10 cents a watt.
enphase, inverter, solar, solar panels
