Old 03-23-2008, 01:03 PM   This thread is in the EcoModder Project Library | #1 (permalink)
fabrio.'s Avatar
tigra AERO - '96 opel tigra
my TIGRA AERO PROJECT
ok boys.
I go to to describe the work on my car.
First, the car is an Opel tigra, year 1996
It is a little coupè, wit only 1604mm of length.
this is a profile of original car
and this below, it is the final solution (without the wheels), but my girlfriends does not want
My mods include:
1) ugly rear underbody extractor
2) fuel tank area covered with polycarbonate ( the exahust line is not covered)
3) front and rear wheel air deflector: the front deflector, deviate the airflow over the horizontal arm
4) grill block: this use three guideline bearing with manual positioning.
5) I do not know what name to give him, I call it: wheel flow stabilizer (WFS).
I is necessary to study it for a good performance.
A lot problem, it come from the rear suspension axle becouse it is exposed to airflow; I have an idea for problem resolution, but any advice is appreciated
Other problem come from the engine undercover not present.
below some pictures:
first three pictures refers at original car (rear car)
now, the pannellings of previus pictures
I have pan all fuel tank area
in this pic, you can look the marked areas covered
Down, the ugly rear extractor
the points of anchor :
from the front:
original
the plastic elements come from this:
in detail:
the FWS
note: final pictures are not available.
In red , the final profile
the idea came from looking the underbody airflow of mercedess SLR
Note the air flow in to the rear wheel, wich cause turbolence (in the slr the flow it is used for brake ventilation)
My friend has an engine undercover Audi, but I discovered it
when this cover is applied to the original bumper, the result like below:
The Following User Says Thank You to fabrio. For This Useful Post:
Piwoslaw (03-25-2010)
Old 03-23-2008, 01:13 PM   #2 (permalink)
fabrio.'s Avatar
more informations at http://tigrafans.forumcommunity.net/?t=7378938&st=0
Old 03-23-2008, 01:13 PM   #3 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Looks like you are off to a great start.
Looking forward to your results.
How are you keeping track of your fuel mileage ? Do you have a Scanguage ?
Old 03-23-2008, 01:20 PM   #4 (permalink)
fabrio.'s Avatar
this is the biggest problem: i do not have any fuel meters.
Thi is for me an atypical case: I am generally precise and meticulous, and for engine mods Always I use the tools needed , but in this case...
Old 03-23-2008, 02:16 PM   #5 (permalink)
fabrio.'s Avatar
the grill block :
I have used, PVC element for the block, and three sliding guide anchored to the front frame.
in the future I will use an electric motor for management grill block opening, or I replacement him with other mechanisme.
an other mod is the replacement of the original windscreen wiper
Old 03-24-2008, 03:14 AM   #6 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Wow, this is a great thread! Keep up the good work...that's a really nice looking car, too!
Old 03-24-2008, 08:43 AM   #7 (permalink)
What is the original Cd of the car?
Old 03-24-2008, 10:54 AM   #8 (permalink)
pontiac trans am - '00 pontiac firebird trans am
jeep 1 - '02 jeep wrangler
90 day: 16.76 mpg (US)
jeep 2 - '07 jeep wrangler x
90 day: 19.39 mpg (US)
Toyota - '09 Toyota Corolla lx
nice car, looks like some good mods
Old 03-24-2008, 02:30 PM   #9 (permalink)
fabrio.'s Avatar
Coefficient of drag: 0.31
Frontal area: 19.16 sq.ft.
I have a little simulation: max speed Vs Cx (Cd)
[IMG][/IMG]
Two engine: in red the the 1.6liters with 100Hp , and blue, it is the 1,4 liters and 86Hp, both engine, with 16 valves.
Old 03-24-2008, 11:06 PM   #10 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Very interesting car!
I like the sliding grille block & undertray. Nice work.
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 148 08-12-2021 10:53 PM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 04:14 PM
Another Autospeed aero article: methods for measuring aero drag Daox Aerodynamics 4 02-14-2008 12:34 AM
New user intro and pick-up aero modding Blackbird Aerodynamics 4 01-28-2008 12:06 PM
Radical Metro Aero Mods? Coyote X Aerodynamics 8 01-01-2008 04:05 PM
