Old 11-14-2011, 06:20 PM   #1 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
Vuilleumier cycle heat pump
The Solar-AC FAQ: Vuilleumier cycle (similar to duplex Stirling)
It uses heat, not mechanical energy, to do the work.
Old 11-14-2011, 07:13 PM   #2 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Correction. It uses heat to create the mechanical motion to pump the heat.
Edit: Let me elaborate. Some of the energy goes to move the pistons and gasses around. The heat pumping is largely done by fluctuating gas pressures in the different areas.
