Old 11-14-2009, 11:06 PM   #1 (permalink)
Lurking footless halls
Silveredwings's Avatar
Dark Horse - '16 Ford Mustang GT convertible Premium
Gutless Beauty - '19 Toyota Corolla SE
Need help finding a BMW EBH
I have an unmodded '02 3-series that when warmed-up, gets 34 to 39 mpg commuting to work. For more than a year though, I've been taking a train and drive only to and from a nearby train station: it never warms up any more. Mileage has dropped to 24 - 28, so I'd like to add an engine block heater but I can't seem to find the right one.
What I've considered:
1. I don't think I can use the freeze plug type in the aluminum block (does it even have freeze plugs?).
2. I bought an inline "circulating" type and found out I don't have room to fit it in the engine compartment.
BTW, it doesn't really have a circulating pump in it. It works only by convection.
3. At one time, there was an OEM BMW part that bolted directly to the side of the block, but I think it was made out of unobtanium. I'd buy one if I could find it.
Click to see article.
The part# Googles up with 2 hits (well 3 but one is a dupe). In both cases, it seems the part is discontinued or no longer available. It was made and sold in Canada but apparently not in the U.S.
Maybe some of the ecomodders from Canada might be able to assist me here. If you know of a BMW dealer up north that deals in this kind of thing (I've read maybe Saskatoon), let me know.
4. The pad-type that attaches to the bottom or side of the oil pan might work. The magnetic type is out because the pan is, of course, aluminum. There is an adhesive type that might have promise (similar to this one)
...if I could find a flat spot on the pan:
5. Lastly, I may try a "non-circulating" inline type that connects to the lower (not upper) radiator hose.
I'm not sure it will help if the thermostat is closed: won't it only heat the fluid in the hose and leave the long straight-6 block in the cold? I'm willing to try it if nothing else pans out (no pun intended).
Old 11-16-2009, 12:58 PM   #2 (permalink)
Red Storm - '93 BMW 318 iS
90 day: 28.51 mpg (US)
Pelican Parts have it? I've pulled some obscure things from their warehouse through the years.
Old 11-16-2009, 02:27 PM   #3 (permalink)
No they don't, but thanks for the reply.
Any sufficiently advanced technology is indistinguishable from magic. - Clarke's Third Law
Old 11-16-2009, 04:10 PM   #4 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
I would start calling dealers. Locals first then I would move north. You'd be surprised what odd parts some dealers have in stock.
You may also call salvage yards to see if they have any engines. You may find on an engine that someone is willing to let you take off. The one you show that is appears to be OE looks like it bolts to the side of the motor.
Don
Old 11-17-2009, 01:17 AM   #5 (permalink)
I'll bet that little jewel was one expensive piece... Based on a few of the specialty parts I've bought for my BMW..
BTW the hose mounted heaters I've put in called for going in the lower hose.
Dave
If it has a motor its worth playing with.......
Old 11-18-2009, 03:40 PM   #6 (permalink)
I read $140 and $88 from dealers in Canada (probably CAD $ as well).
Dave
Right you are.
Interview with BMW aerodynamicist Hans Kerschbaum Piwoslaw Aerodynamics 13 06-11-2010 04:59 PM
BMW advocating for smarter traffic lights abroad and in U.S. MetroMPG General Efficiency Discussion 14 11-13-2009 11:34 PM
BMW Vision EfficientDynamics Concept 0.22Cd lunarhighway Aerodynamics 24 09-23-2009 10:08 AM
Article: BMW Plans All-Turbo Line RH77 General Efficiency Discussion 2 10-10-2008 12:10 AM
BMW gets it! sort of lunarhighway Aerodynamics 8 09-09-2008 03:06 PM
