Old 09-22-2008, 04:08 PM   #1 (permalink)
Need help with starter button
Hey all, I have a 97 metro I picked up last week, and I'm in the process of installing an injector kill switch and push button start on the shifter. I have the injector kill up and running, but I'm having trouble with the push button start. Funny enough, if I understand it correct, the start should be far simpler then the injector kill, just a switch in parallel with the starter circuit somewhere behind the key switch. My problem is I don't know which wires to splice into, lol. I can't find any info online for color codes or socket positions. If it matters, I'm using the identical injector kill switch system as bbjsw10 except I'm using a rocker switch rather then a momentary to control the relay (I have a momentary for the starter circuit). Thanks for the help.
Old 09-22-2008, 11:01 PM   #2 (permalink)
Steady as she goes
RacerX's Avatar
Shooting Star - '95 geo metro
90 day: 59.91 mpg (US)
HUFFER - '98 Buick Riviera Super Charged
90 day: 30.69 mpg (US)
Kandy, Flake-n-Flames - '96 Buick Riviera Base
90 day: 32.13 mpg (US)
Blue Z - '07 Nissan 350Z coupe
90 day: 34.13 mpg (US)
Going from your ignition switch to the fuse block.....There should be a RED wire with a YELLOW tracer. That should be your 12volt wire that applies voltage to the starter to pull the solenoid in, So that it cranks. That RED/YELLOW wire.. I think plugs into the face of the fuse block and is close to the size of a 10/12ga wire. I myself thru a relay in, in my '95 ....to take the load off of the switch. Good luck
How about a 1 Litre Street rod?
Old 09-23-2008, 08:59 AM   #3 (permalink)
Excellent RacerX, thanks for the help. I figured it would be a lighter duty circuit since it's only activating a solenoid, but if it's that beefy, yeah I guess I should use a relay.
button, engine kill, injector, start
Alternator Delete VS starter motor bennelson EcoModding Central 25 02-04-2017 11:03 PM
DIY: Push Button Start SVOboy DIY / How-to 20 07-10-2014 09:43 AM
Starter went out millenniumtree EcoModding Central 9 08-25-2008 11:15 AM
I'm curious about a "nitrous" style engine kill button Volones DIY / How-to 38 05-22-2008 12:12 AM
Saving a dead jump starter WaxyChicken Off-Topic Tech 6 01-24-2008 06:14 PM
